Question about Belling Ovens
Carnt set the clock on a belling synergie multifunction model number xou270ss
The clock flashes twice then pauses for a second then flashes twice again it wont stop flashing when i try to set it so the oven wont lite up
  • 1462 Answers
SOURCE: zanussi oven wont work. clock flashing 'auto'
you need to set clock before oven will work. do you still have instruction book as it will tell you there how to do it
Posted on Jun 19, 2008
SOURCE: belling synergie. oven
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Posted on Aug 19, 2008
  • 417 Answers
SOURCE: Faulty Oven
Have you tried www.appliance-parts.co.uk, they have a useful parts finder service.
Posted on Nov 30, 2008
SOURCE: How do I find the model number on belling synergie oven?
I have the same problem. I have inherited a Belling Synergie multifunction double oven. The Model No is worn out - yet there is a specification 492SS which isn't. I am going to purchase the element with this number and hope this works.
Posted on Mar 28, 2009
SOURCE: can't get my belling oven to work
Press & hold both the 'Cook Time' and 'Stop Time' buttons together and, while holding both of them down, press either the + or - button (this is the way to set the time of day). Release all buttons simultaneously. This should enable the cooking functions to operate.
Posted on Apr 27, 2009
Manual needed for belling multifunction synergie 50/50 oven
You can probably order a manual from the manufacturer. But if all you need is a schematic, check out the internet. Sometimes the manufacturer places a diagram right on the back of the device or in an envelope inside the cover (but not always!).
Nov 30, 2015 | Belling Ovens
My Belling Synergie 482BL grill blew out yesterday
It's hard to say without actually seeing it, was it shorting out on the bracket that was supporting it? If so, this would be a weak point on the element and as it broke down it could have shorted out to earth through the bracket causing the bang/flash and tripping the breaker. If an element is just touching another metal part it won't short out because the filament is insulated from the casing. You should be able to find the element code on the casing near the terminals. Hope this helps.
Nov 11, 2013 | Ovens
Operating Instructions Required for Oven
Ask your landlord how it works .or try Google for a manual
Mar 01, 2018 | Ovens
How do I set clock on Belling Synergie Multi-funtion oven (xou270)?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To set the clock
hold the cook and stop buttons together at the same time then use the up and down arrows or+/- to set the time in 24 hour format
Jan 30, 2010 | Belling XOU252 Electric Single Oven
Fan oven option not functioning on main oven, its a Belling synergie multifunction oven, about 5 years old
On my Belling it was the oven multi function switch that was faulty. I replaced it - carefully (lots of coloured wires) and it works fine now. Hope this helps
Oct 24, 2009 | Belling XOU590 Electric Double Oven
Mar 23, 2009 | Belling XOU174 Electric Single Oven
Belling synergie oven - main oven won't come on.
hi
check the timmer clock is not in auto mode as this will stop the oven from turning on. if clock ok then fault could poss be the thermostat
hope this helps you
regards dan
Mar 03, 2009 | Belling XOU174 Electric Single Oven
Faulty Oven
Nov 30, 2008 | Ovens
Belling multifunction user manual
modle number 44445847
is that all you need?
Jan 06, 2008 | Ovens
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Ovens Logo
99 people viewed this question
Top Belling Ovens Experts
Craig Butler
Craig Butler
RudeRude
Are you a Belling Oven Expert? Answer questions, earn points and help others
