Question about KLH R3100 Receiver
Stereo receiver control problem
The display will not lite up and the front controls will not work, works fine with remote.
  • 1 more comment
  • que957 Feb 24, 2008
    The reason I posted the problem is that it needed repair. I need to know how to repair it?
  • que957 Feb 26, 2008
    The unit is out of warranty and I don't think there are manuals available. I don't think I need someone to tell me to take it to a shop or read a manual. The quick fix items in the operating manual (plug it in etc)are not what I expected from this forum either. Does anyone have experiance on this model that they can relate?
    I cannot accept that ALL of the buttons should die at the same time. There are 18 buttons and dials that are inop.
    Sergeant:
    Champion:
  • 281 Answers
The buttons of the receiver are dead. I mean you should change them. Take off the front of the stereo and replace the old buttons with the new ones. Hope this helped you.
Posted on Feb 26, 2008
    Genius:
  • 1,019 Answers
if the unit is warranted return to suppliers, they,ll do a cost effective repair.
there may be internal fuses blown, but these are,nt probably fuses as you,d know them. i.e glass-wired et,c. they,ll be on-board components resembling small rectangular blocks. usually white/black.
There are possibly l.e.ds at either end of the tuner bar, which may be replaceable, or soldered connections.
if you feel confident, and the units out of warranty, probably worth a look.
Mike @ compurepair.
Posted on Feb 24, 2008
    Genius:
  • 3,587 Answers
Well..then you'll need a repair manual, no? Can you characterize your technical skills, please?
    Scholar:
  • 110 Answers
It's likely that the ribbon cable connecting the front panel to the mainboard has come loose. Make sure your unit is unplugged, then remove the screws holding the top cover in place. This should give you easy enough access to check the ribbon cable connection.
    Genius:
  • 3,422 Answers
Your set really needs a repair. There is a pair of bulbs behind the display that burn out.this is the reason why you are not getting the display.If you can see the info when there's light in the room, but there's no light in the display you probably need to change the lamp/LED that lights it. If there's no info at all then i am sad to say that it has to be repaired.
Goodluck..
Optimus stereo receiver universal remote codes
go to link below and click the green "Notify Me" button when this item is stocked. We will inform you when we put one in stock. You must purchase a new OEM remote, universals will not work. OPTIMUS STA3750 3760 Remote Control
Apr 17, 2014 | Optimus Sta-3750 Sta-3760 Stereo Receiver...
Setting remote to control stereo receiver.
Switch stereo on and try one of these codes at a time. didn't know if it wasa 3 or 4 digit code you needed so i listed them all. If the none of these work try putting a zero in front of all the 3 digit codes. ie. 0626, 0706 etc.
hope it works.
Hughie.
0706, 0806, 0858, 0859, 0681 0689
626, 706, 726, 806, 858, 859, 601, 609, 618, 681, 689, 698,, 859
Jun 19, 2009 | One For All URC-6131 Remote Control
Rs2100 bookshelf stereo
The Audio System does not respond to the remote control.
1. To reset their connection, turn on the remote control and switch the Audio System to Standby mode.
2. In Standby mode, press and hold both INFO and SOURCE on the front panel of the Audio System. It is reset to default when"RF ID clear" displays.
3. Press and hold both PROGRAM and SELECT on the remote control. When “ID claer” displays on the LCD of the remote control, the connection is reset.
4. By now the remote control and the Audio System should be connected to each other. Press and hold PROGRAM and SELECT on the remote control again. When
“ID Locked” displays on the LCD of the remote control, the connection between the remote control and the Audio System is locked.
Jun 06, 2009 | RCA RS2100 Shelf System
Remote control won't work
Could need a new ir sensor or repair solder connections on the display (ir) board. You can check that the remote is putting out a signal by viewing it with a camcorder, turn the camera on look through the viewfinder and point the remote at it push a button. If it is working you will see a flashing light on the remote.
Feb 08, 2009 | Sony STR-DE197 Receiver
Wireless remote control extender
Possibly your new equipment doesn't use IR (infared) as the media for the remote. I have used the pyramid and different versions of it for DirecTV/Dish and most everything else for years with no major problems. occasionally a unit will fail, but that happens. If the red light blinks on the "transmitter" (no antenna) it should indicate that it is receiving IR from the remote. The "receiver" (antenna) has to be oriented correctly in front of the unit to be controlled. I put the receiver no closer than 5' to the unit. The signal coming out is a cone shape and it's easier to aim the further away you are. As a test, you could try using the remote to control a stereo or something else, even a fan. If the remote has a led or a dark red plastic cap on the front end, it should be an IR unit.
May 07, 2008 | Radio Shack Wireless Remote Extender...
No receiver display lights
Hi ripper
The unit has a built in display dimmer, with a button to control the level of brightness from the display both on the remote, and the front panel.Try this
regards
Graeme
Nov 16, 2006 | Onkyo TX-SR601 Receiver
KLH R3100 Receiver Logo
140 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
