Using Home Loop system on Sony Bravia lcd TV
My home loop system (for hard of hearing) works fine when watching TV channels, but trying to use Sky or VHS recorder (connected via scart leads) the TV channel soundtrack remains, Any ideas?
  • me4a Nov 27, 2008
    I have the same problem. Someone advised if I used an audio cable to connect the sky audio to the HD ready TV this should work.
    Someone else suggested if I connect the loop system directly to sky as opposed to TV. I have yet to try both of these methods and will report back if it works.
    Champion:
  • 206 Answers
Simply sound like you have something hooked up wrong, The best way we recamend for these is to have the sound source come directly from the tv's audio source this way what ever the set is playing is what the audio will be, it sound like you have the audio souce now hooked to the cable box so the inputs can not change
Posted on Feb 13, 2008
Toshiba lcd tv 32" making noise by speaker
test this steps and fix it. God bless you
Line noise is feeding in from the AC line. Use an AC liner filter to block the line noise. RF (radio frequency) interference is being picked up by the power line or wiring. Remove sources of RF interference, such as fluorescent lighting or wireless devices not designed to work with audio/video equipment. Wires between the components are on top of one of the components; the transformers are causing RF interference. Be sure that wiring goes behind the components rather than on top or between components. If there is an equalizer in use, there could be a ground loop. Ground loops can be resolved by installing GLI's (ground loop isolators) on the cables connecting to the equalizer.
Jul 25, 2013 | Toshiba 32AV502U 31.5 in. LCD HDTV
Get demo mode (loop) off my Sony TV
Press the home button and hold it will reset to factory setting. This was a in store option to display what is in the TV. Sony told us how to fix it. Press the Home button and hold it for a few seconds.
Dec 27, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
We recently purchased a sony bravia 55 inch tv. we have a hdm1 cord and have hd channels through Telus optik. i am not certain we have it hooked up for the best picture? can you please instruct us on what...
If you are using the HDMI input, you are using the best hook up that is available.
Is there a particular problem with the picture that does not look good?
Skyassoc
Nov 24, 2010 | Sony Televison & Video
How do i get rid of the demo loop on my sony lcd tv
go into your home menu - then into setings and then restore factory settings and reset tv up.
Sep 19, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Hissing and Humming when trying to use the speakers for the tv
The sony manual tells you how to connect to a TV however most of us now watch TV connected to a SKY box. The Scart lead needs to be connected to the Sky box for the sound to work correctly. Ignore the Manual and connect the Scart lead from the DVD Unit directly into you're sky box. It works fine.
Apr 04, 2010 | Sony Audio Players & Recorders
DVD Does not work when using HDMI from Philips TV to Bravia
You could see if they will exchange just the unit and save both of you the hastle of checking and repackingit all. It does sound like the unit is faulty.
Or if your Bravia has more than one HDMI input then try on another, or a friends tv if you know some one with a HDMI tv in working order.
Apr 29, 2009 | Sony DAV-FC8 System
Tuning Sony KDL 32U3000 for Sky TV
Hi Max,
I an not familiar with Sky TV, I assume it a Cable or Satilite Service.
Here are a few things to check.
  1. Press the INPUT button on the TV remote or on the TV control panel, cycle through all inputs and see if you get a signal.
  2. From the TV's Video Menu, set tuning band to Cable and not to Air or Antenna.
  3. From the Video menu Scan for channels, there should be a Auto Scan option.
Try these and let me know how it goes, I can be of further assistance.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Feb 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 05, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
