Bypass Tray Troubles
I just purchased a new bypass tray for my xerox copier model 5018. when i put the tray in a light comes on that says "close the door". the bypass tray does not have a door to close, it just slides in on the side....help
  • kentyankee Feb 20, 2008
    I had previously received that advice and that solved the "door closed" problem but now the machine will not pick up the paper from that tray.
    The copier acknowledges that that is th tray it is suppose to be using but it will not feed regular paper or card stock. Does not even try to pick up the paper. Gives me an error message saying "misfed paper"
  • Anonymous Mar 21, 2014
    clearing jam and now it woin't shut
    Genius:
  • 1,665 Answers
Quick references to diagnostic codes as well as troubleshooting suggestions for each machine self-diagnostic code. try this guide if you have manual
http://www.precisionroller.com/handi-guide-manuals-for-xerox-5018/details_19725.html
Posted on Feb 20, 2008
  • 1 more comment
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Feb 20, 2008
    correct "if have NOT manual"
    Make sure to Clear all Paper Jams From Inside the Machine
    http://www.support.xerox.com/SRVS/CGI-BI...)
    Xerox 5018, 5028
    ERROR
    A1
    Document is ADF
    A1-8
    Main board received reset signal
    A2
    ADF jams
    A6, A7
    ADF jams
    A9
    ADF jams
    C1 - C4
    Feed jam
    C5-1 to C5-4
    Jams in various areas
    C5-2
    C5-3
    C5-4
    Duplex jam
    E0
    Machine has reset
    E1
    Jam
    E1-E0
    Registration jam
    E1-E5
    Clamshell interlock
    E1-E6
    Right side interlock
    E1-E7
    Two tray interlock
    E1-E8
    Sorter interlock
    E1-E9
    Copy cartridge interlock
    E2
    Reset signal happened
    E3
    Jam
    E4
    Exit jam
    E4-10
    Exit jam
    E4-5
    Clamshell interlock
    E4-6
    E4-7
    Two tray interlock. Duplex interlock
    E4-8
    Sorter interlock
    E4-9
    E5
    Clamshell interlock
    E6
    E7
    Duplex interlock
    E9
    F3-1
    Sorter bin home switch
    F3-2
    Sorter cam switch
    F3-3
    Sorter cam switch
    J1-1
    Add toner
    J1-2
    Temporary low toner signal
    J2-0
    Replace copy cartridge
    L2
    2000 copies left on copy cartridge
    L3
    ADF to machine communication problem
    L4 (flashing)
    1000 copies left on fuser web
    rr
    Bad EPROM on main board
    U0
    Main board
    U2
    Scan problem
    U2-1
    Scan home
    U3-00
    Cam drive problem
    U3-01
    Cam movement slow
    U3-04
    Main board to duplex communication
    U3-09
    Cam problem
    U3-12
    Jogger problem
    U3-19
    Cam problem
    U3-21
    Cam problem
    U3-23
    Cam problem
    U3-29
    Cam problem
    U3-32
    Cam problem
    U3-34
    Cam problem
    U3-39
    Cam problem
    U3-43
    Cam problem
    U3-45
    Cam problem
    U3-49
    Cam problem
    U3-54
    Cam problem
    U3-56
    Cam problem
    U3-59
    Cam problem
    U4-1
    Fuser problem. Long warm up
    U4-2
    Low fuser temperature after warm up
    U4-3
    High fuser temperature
    U4-4
    Open fuser thermistor
    U4-6
    Replace fuser web
    U4-7
    Thermistor signal problem
    U7-1
    Copy cartridge belt drive problem
    U9-3
    Exposure lamp problem
    U9-4
    Toner motor
    U9-5
    Problem in warm up
    > Support & Drivers > 5018 Copier Support > Paper Jams Inside the Machine
    Solution: Clear all Paper Jams From Inside the Machine
    Make Printable
    Email this page
    1. Pull the Sorter or Output Tray away from the machine.
    2. Pull the release latch to open the Clamshell. The release latch is located on the front, left side of the machine, below the Control Panel.
    3. Remove any paper found inside the machine. If necessary, lift the baffle higher to expose any hidden paper. The baffle is a black plastic piece with four wide black rollers attached. Look for full and partial sheets of paper that may be causing the jam.
      CAUTION: The Fuser area may be hot!
    4. Lift the silver baffle and remove any paper. The silver baffle is a metal flap. There are two sets of rollers positioned across the baffle. The top set of the rollers will lift up when raising the baffle.
      NOTE: Some machine models may have a green handle. If there is a green handle in the Fuser area, lift the Fuser baffle higher to expose any hidden paper.
    5. Push the Sorter or Output Tray toward the machine.
    6. To close the Clamshell, stand on the left side of the machine and push down on the front and back corners of the Clamshell using both hands.
      NOTE: If you cannot remove all the paper jammed in the Fuser area, power OFF the machine and call for service.
    Genius:
  • 1,226 Answers
Please reset the copier maybe unplug it on the wall to automatically reset the setting. please refer to the manual in installing the tray make sure that the tray is match in you copier. it should be same size and if possible it should be replacement and copied designed with the old one.
    Genius:
  • 3,587 Answers
That close the door, usually means the main cover panels. Are you certain that all of them are fully closed. any one of them being slightly ajar can cause that..or the tray may not be fully seated. remove it and slowly insert it again. If there are any fit issues, then remove it, inspect inside, for obstructions, then try again.
Posted on Feb 12, 2008
  • Patrick Michaels
    Patrick Michaels Feb 20, 2008
    ok..that's a pickup assembly issue. Are you using good quality paper? is it 'riffled'(meanging fluttering the paper with your hand, prior to inserting the paper..this still is a good idea.)
    thanks for the Best Solution.
    got backup for your computer?
  • 4,102 Answers
Has your copier got a door that opens an closes if it has switch it off then press and hold the door or flap down and see if this removes the message doing this would tell you that the problem is not with the door then we can look at other possibiltys let me know what happens ok
  • paul proctor Feb 12, 2008
    sorry switch it back on whilst holding the door or flap down and see if this removes the message your having let me know then i can assist you further ok
HOW do I get my printer to stop trying to print from the bypass tray?
check the printer properties in Windows Control panel and see if printer settings are set to bypass tray
Sep 19, 2014 | Xerox Office Equipment & Supplies
Xerox workcentre c2128 When i put paper in bypass tray, sensor dosnot detect this paper
You must manually define the papersize and orientaion of bypass tray at the printer console or printer driver.
Then print bypass tray (e.g. Tray6 on our Xerox).
Apr 13, 2014 | Canon Computers & Internet
How do i print envelopes on a Lanier LP331cn laser color printer?
You should see a bypass tray near the main paper tray. On laniers it is recommended you use the bypass tray for envelopes.
when you send a print job make sure to select the bypass paper tray option
Oct 08, 2009 | Xerox WorkCentre PRO 128 Copier
Printer trying to print from the bypass tray
check your software setting OR delete and re install your software
Sep 19, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Printer always prints from bypass tray...
Check the setting in / on your computer. Make sure it is not set to default to the bypass tray.
Jan 08, 2009 | Xerox WorkCentre M128 Copier
Can't Print Envelopes from the Bypass Tray
you have to tell the printer in the print que that you are using envelopes and what size envelope.
-Carl, please let me know if this helps.
Oct 29, 2008 | Xerox WorkCentre PRO 128 Copier
Unable to print envelopes on Xerox WorkCentre Pro 123
Some thoughts.
Envelopes won't print from bypass tray. Cause:
Extended tray is not set up properly for envelopes. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Enter tools "Login" 1,1,1,1,1 Touch buttons with the following names in that order: System Settings System Settings Common Settings Other Settings Scroll down to "Extended Tray" Next to "Extended Tray" it may say "Inverter" if it does go to change settings then change it to "Offset Stacking" Close out tools.
Nov 22, 2007 | Xerox WorkCentre Pro 123 All-In-One Laser...
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
165 people viewed this question
jasbo
jasbo
