Cable to connect laptop to TV
I am seeking a cable to connect my laptop to my TV
  • 2 more comments
  • TomGavin Feb 12, 2008
    Sorry for the lack of info.
    It's a Compaq C300 laptop, to a LG LCD TV which has VGA input.
    Thank you.
    Hi- many thanks for your advice. I'll let you know!
    Tom.
  • ohiotom May 11, 2010
    There are a couple of variations of the Compaq C300 on their website. I looked at one of them and it appears to have a VGA output (like all laptops) as well as an S-Video output. You've already said your TV has a VGA input so you can definately go that route, or you can use the S-Video cable. The S-Video cable will probably be a bit less expensive, although you can find VGA cables on the web for a reasonable price. I believe you'll need a male to male VGA cable, but you should check the connector on your TV if you decide to use the VGA. Remember, if you want to hear audio through the TV, you'll need audio cables too. The VGA and S-Video are only for video. For audio you'll have to use the headphone jack on the computer so you'll need a cable with a standard headphone jack on one end and you'll need male composite connectors on the other end. You probably won't fine one cable that will give you what you're after for audio, but you can buy a few pieces and put them together easily. You should be able to locate everything you need at Radioshack or BestBuy.
    Pay attention when you plug the audio into the TV that you're on the right connectors. Typically each video input has a seperate audio input. If you put the audio cables on the wrong connectors you won't hear anything...
    Lastly, once this is all hooked up you'll need to enable the correct video output on the Compaq. According to the Compaq manual you can switch between video devices by using the fn+f4 keys. If you have the manual for the computer, see chapter 5 (multimedia) for addtional instructions.
    Best of luck. If you get stuck or have more questions, just ask.
    You're not giving anybody much to go on here...
    What kind of laptop is it? It may or may not have an output that will connect to any type of TV.
    What kind of TV are you trying to connect to? Some TV's have VGA input's, most dont.
    If your computer does not have the right type of output there are boxes you can buy, but I've never used one.
I am investigation the last advice given to me by FixYa. This may take a few days.
I will report back.
Thank you.
Posted on Feb 13, 2008
Can not get sound when connecting a samsung HW f355 soundbar to a sharp aquos 4k tv
There should not be any problem in connecting this TV to Sound Bar. Check all the connections. Contact any service technician to seek help in this matter. Refer the user manuals to both the sets.
Dec 02, 2014 | Samsung Televison & Video
VGA from the laptop to whatever the TV takes.
Mar 19, 2014 | Computers & Internet
I have a toshiba satellite p755, it use to be able to hook up to my HD TV with the HDMI chord but now its not connecting..whats the problem?
Make sure all connections Power ,HDMI and any other connecting leads have secure dust free connections also check each lead for any kinks / bends .
Connecting a Toshiba Satellite Laptop to a TV is an ideal way to enjoy videos, photos and other media on the laptop on a much larger screen.
Satellite Laptops can be connected to TVs using VGA, S-Video and even HDMI, though the TV has to have compatible inputs as well.
Connect the RGB cable or S-video cable to an open input on the TV.
Depending on the type of TV, it may or may not have a RGB input.
S-video may have to be used instead.
Connect the 1/4 inch to RCA Y-cable into the TV using the same input as the VGA or S-video cable.
Connect the other end of the VGA or S-video cable and the audio cable into the laptop.
The video ports are on the sides of the laptop.
The audio cable should go into the headphone jack of the laptop.
http://www.svideo.com/compaq1700.html
Aug 09, 2013 | Computers & Internet
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
Connect laptop to tv
To connect a laptop with a Sanyo TV, the TV must have VGA cable connection. VGA cable picture
If the TV is not equipped with a VGA cable, it can not be be a laptop and a TV connection.
Jan 07, 2012 | Toshiba Satellite A665-S6086 16-Inch...
How can i connect my laptop ibm R51(2887) AE3 to TV using svideo cable
Hello - It's really fairly simple. You need the S-Video cable and if you want sound a 3.5 mm stereo cable with whatever connector on the opposite end that your TV requires (probably stereo RCA male connectors.)
Here is an illustration direct from IBM about setting up the R51 to TV connection:
Enjoy and thank you for using Fix Ya.
Mikeywaf
Mar 22, 2011 | Computers & Internet
Laptop connected to TV via 23pin cable and setup
You have to connect the laptop to the TV by using the headphone jack on the laptop.
Only then, will the sound be sent over to the TV, and automatically the speakers on the laptop will stop working.
Get a cable to connect them from the headphone jack to an appropriate input on the TV.
Hope I helped,
Tom
Jun 21, 2009 | BenQ Computers & Internet
Need instruction booklet for this tv
The command you seek is in the remote. You will have to experiment as to what menu item will separate an over the air signal to cable. It should say on the menu screen and it will direct you....seek and ye shall find.
Dec 30, 2008 | Insignia NS-13CTV
SCART SOCKET SCROLLING PICTURE
Its probably a bad cable otr the connections inside the set where the scket connects to the chassis has broken connections on the mounting. To fix this your gonna need to know how to solder and know the HI Voltage issues with tv sets so if you dont please seek a pro to assist you with this repair. Good Luck
Jun 26, 2006 | Panasonic TX-29PM1F 29" TV
Computers & Internet Logo
819 people viewed this question
Alun Cox
David Payne
David Payne
