Question about Dewalt DW746X 10" woodworker's table saw with rai
Router Repair Router mfg in 2001, but has about 2 hrs run time; first indication of problem was needing to wait to re-start after router ran for a bit; now router won't start. Local factory repair thought maybe needs new brushes. Odd in view of low use time. I'll take apart myself. What might be the more common causes of the router not starting? This model has an odd feature of waiting to re-start until the bit stops spinning in total. Is this maybe the problem? I have to question any possible loose wiring problems. Thanks, Vic
  • 25 Answers
Unp[lugt the unit and remove the brushes then blow out the brush cavity and try it. If no fix, unplug it and remove the switch and bypass it by wiring direct being very careful as the high rpm generates lots of torque. Don't let the unit get away from you during this exercize. Next I would check to make sure the cord is not causiong the proper. The last thing would be to check the field wiring as a last ditch effort.
Posted on Apr 29, 2008
How do I recover from forgotten admin password?
Some routers have passwords printed on the bottom. Most routers use "admin" as username, and then either default password or unique password. In any case, read the user manual, you should find it there. Download Free Manuals
Jan 09, 2016 | Computers & Internet
I accidentally plugged the router out and now my Internet connection doesn't work. The local network connection is displayed as working and responding nevertheless. The second and fourth (starting...
Power down your router and computer. Wait 15 seconds, then turn on the router first, then the computer. If this doesn't work, you can also try rebooting the modem as well. You will then need to power all three down, then start with the modem and wait a minute as it boots up and runs its auto-tests, then the router, then the computer.
Jun 20, 2011 | D-Link DIR-300 Wireless Router
Have dsl connection, works fine. when linksys wrt54g router is correctly installed, no internet connection! ran diagnostic, all is fine, but no internet connection found-can't seem to upload new firmware...
Turn the DSL modem off.
Turn the Linksys router off.
Turn your computer off.
Turn the DSL modem on.
Wait for its lamps to settle-down to a consistent pattern.
Turn the Linksys router on.
Turn your computer on.
Wait for it to settle-down.
Click Start
Click Run
Type CMD
Press Enter
You should get output somewhat like: Default Gateway ....
if you have a connection between your router and your computer.
If you have that connection, you should be able to upload new firmware from your computer to the router.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
My modem is working perfectly on my notebook then i installed my Linksys router on the modem and router to my notebook. I turn on the power of my modem everything is light up then i power on my router,...
Wireless broadcast is usually the first thing to go when a router is failing. How old is your router? Try these steps:
Turn off computer
Remove power from router
Remove power from modem
Wait 2 minutes
Restore power to modem
Wait for modem to boot up and gain all signals
Restore power to router
Wait for router to completely powerup
Watch for wireless indicator light
Boot up computer, verify your wireless network is broadcasting
If you still can not get the wireless network to access the internet, try connecting your computer with an ethernet cable. If everything connects fine and you can access the web, it might be that your router is going bad and needs replacing.
Try running the ethernet cable from the modem to port #2 on your router. Then run the second cable from port#3 on the router to your computer. This effectively uses the router as a pass-thru and bypasses all its functions. If you are able to access the internet this way, you need to replace the router.
Jun 26, 2010 | Linksys Wireless-G WRT54GL Router
My 2001 tahoe dies while idling in park. After waiting over night it started and ran fine until allowed to idle in park for a short time. This a 2001 Chevy Tahoe with a 5.3 liter engine and 160,000 miles.
If the only problem is idle and it runs grat above ide then the most likely component is the Idle Air Control valve. This is providing you have no codes stored indicating something else.
Mar 13, 2010 | 2001 Chevrolet Tahoe
Unable to connect through wireless router
This is a mfg problem with the Atheros wifi cards used in hp laptops. Have a new wifi card installed at your local pc repair shop.
Sep 16, 2009 | HP Pavilion dv9000z Notebook
WLAN indicator won't stop blinking when router is reset
i think blinking indicator is not the reason but if the indicator are not blinking that would be problem.. you are getting a internet provider, right! contact your internet provider for this problem because maybe its not your router in the problem or maybe them...
Jun 19, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
1613EVS Plunge Router will not operate. Does not start !
hello- had same problem with similar model-- problem is definitely DUST INSIDE THE SWITCH, it must be blown out with compressed air- i had this done at a repair shop (for free) so i don't know if they had to disassemble anything- hope this is helpful
Nov 16, 2008 | Bosch Plunge Router
NetGear Wireless Router not working
No need to worry about this issue,,,,
turn off ur router for 2 minutes..wait for 1 minute..turn on the router and wait for other 2 it should work..
If still its not working means..there will be a reset button in the the reset button and hold it for 60 secs..turn off ur router and turn it on..wait for 1 minute..
try to connect thru will work
Jul 03, 2008 | NetGear WGR614 Wireless Router
Wireless connection
The first step to try is to reboot both the router and the cable/DSL modem. Turn off your computer, and unplug the router and the modem from the mains. Wait one full minute, then plug the modem back in. Wait until the lights stop blinking (until it indicates a steady connection). Once that is complete, plug the router back in, and wait until it also stops blinking. Once the router and modem are both back on, then turn your computer back on and check to see if you have a connection. If that doesn't work, then take the router out of the picture -- plug a computer directly into the ethernet port on the modem. You should definitely have an Internet connection at that point. If it works, the problem is in the router. If it doesn't, you'll need to call Virgin Media's help desk for assistance.
Sep 29, 2007 | Belkin (F5D9230-4) Wireless Router...
Dewalt DW746X 10" woodworker's table saw with rai Logo
62 people viewed this question
Top Dewalt Saws Experts
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
