Question about HP Photosmart C7180 All-In-One InkJet Printer
Connecting my hp all in one printer c7180
Can i connect using a usb cable to my pc and wireless to a laptop, thanks Peeb
  • PeeB Feb 12, 2008
    Thanks for the help, This is my first visit to this site,very impressed! Peeb
    Genius:
  • 3,587 Answers
Sure...no worries..only thing is that if you want a small business network with pc and laptop, then you'll find out that you may need to work around that.
got backup for your computers?
Posted on Feb 12, 2008
How can I set up my HP C7180 to scan to my second laptop, a VAIO VPC-EB33FM/B
To be able to scan to the laptop it MUST be connected to the printer either with a usb cable or through the router. There is a way to bypass the wireless functionality of the router and laptop. Use an ethernet cable to connect your laptop directly to the router. It should work right away. It's highly unlikely that Windows XP will not work the wireless router. I would suggest you contact the actual manufacturer of the router instead of verizon.
May 07, 2015 | HP Office Equipment & Supplies
Printers not picking up usb cable
remove usb cable from pc
uninstall hp software.
reinstall hp software without plugin usb
follow the instructions
Mar 18, 2014 | HP Deskjet 2540 Wireless Color All-in-One...
How do i connect an hp officejet printer to a wireless laptop
Download and install the drivers & software necessary for your printer from HP's website (www.hp.com) on your laptop. After the software and/or drivers are installed, connect the printer to the laptop with a usb cable. As long as the software is installed the pc should recognize the printer as soon as the usb cable is connected. Then just print as normal.
Oct 26, 2011 | HP OfficeJet 6110 All-In-One InkJet...
How do i connect my laptop to my printer so i can print things of my laptop
I will try to guess that you want your printer connected to your laptop as wireless.
-first you need to prepare all the things needed and make sure that you connected/installed the cartridges and you have located the port where your power cable needs to plug-in.
-2nd I hope your laptop does have an optical drive (CD/DVD drive).
-on the package of your printer there should be a drivers disk.
-you need to enter the drivers disk on the optical drive then just let it run.
-when you have the GUI of the driver there is an option to install everything.
-make sure that you did not connect your USB cable to the laptop if theres any.
-when running the driver it will come to a point where it will ask you to connect the printer (USB, Network, Wireless)
-if you have the USB cable, use that cable first to connect after you turn on the printer.
-later after the installation was completed, run the disk again then there should be an option to convert the connection from wired to wireless.
-if you dont have the USB cable comeback to me then I will give the the steps to connect it using wireless connection.
Apr 10, 2011 | HP DeskJet F380 All-In-One Printer
How to wirelessly access HP Laserjet 1320n via Apple iBook
You need to disconnect the USB cable and set it up wireless on both units:
Since it is plugged into the router, it should already have an IP address.
Un-install the printer from the computers.
Then re-install the printer from the cd or from HP's website. When you get to the point where it ask you is the printer is attached to the computer or is it over the network. Choose over the net work and the software will find the printer IP and finish setting it up wireless.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 13, 2009 | HP PhotoSmart 1215 InkJet Printer
HP Photosmart C7180 not scanning
I had this very same problem yesterday & solved it, after about 4 hours, with a clean install!!
Check my "solution" post at another question where I explained it in detail.
Jack
Dec 29, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C7280 wireless connection
My experience is different. My DSL router died in the night and I had to install the old one. I just changed the wireless settings on my C7280, and now all three connections work. If no wire (ethernet or USB) is connected, the wireless connection works. If the Ethernet cable is connected, it works via Ethernet, and if the USB cable is connected, it works via USB. It seems to default in that order.
Oct 29, 2008 | HP Photosmart C7180 All-In-One InkJet...
Connecting Toshiba laptop using windows vista to C7180
Hi there i know that HP are updating a lot of the drivers at the moment you could try the following websites
www.hp.com (Free download)
www.drivers.com (Small charge)
I hope one of those helps but also try the XP driver as may vista might work on XP driver technology.
Thanks J
Jan 19, 2008 | HP Photosmart C7180 All-In-One InkJet...
Weird situation
Did the problem start after a Vista update? That's when mine started...
Oct 04, 2007 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C7180 All-In-One InkJet Printer Logo
123 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
