Our aeg washing machine stopped mid-cycle it had in 4 pairs of trainers. it clicks from the door latch area too.
  • 54 Answers
Try the door lock. if not im afraid it will need a pcb witch a tech will have to configure.
Posted on Feb 12, 2008
Aeg protex how to open door mid cycle
To open door during mid cycle, turn off washer by plug and wait a couple of minutes until you hear a click, then the lock light ( assuming it has one ) will release, but make sure there is no water in the tub before opening the door. If possible when door is unlocked, run the drain setting and let the water pump out before hand. Hope this helps.
Aug 16, 2014 | AEG Washing Machines
AEG Lavamat W1450 Electronic - after about 10 mins of programme machine is making beeping sound and stopping
this is an errorcode !
try to download a servicemanual,
then you can figure out the exact failure -
like : does not heat up etc. ....
May 05, 2012 | AEG Lavamat W1450 Front Load Washer
Turned off mid cycle. Tried putting back onfor drain, also rinse and restart. Each time get error E40.
Hi.
With AEG washers E40 means defective door lock. Since a faulty door lock switch may go out with vibration you often do not get the error all the time. The door lock switch must be tested and eventually replaced. Call the AEG number listed in the user manual if you want to get in touch with an authorized technician or if you need replacement parts for your washing machine.
Regards.
Ginko
Sep 18, 2011 | AEG Washing Machines
About mid cycle, a significant amount of water leaks out of the bottom. No error message comes up and the machine continues functioning. Machine is AEG oko lavamat 72640
Could the machine be overfilling due to a faulty pressure switch (controls the amount of water in the drum). Splits in the door seal or broken pipes?
Jan 25, 2010 | AEG Lavamat 72640 Front Load Washer
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
Door does not open after a wash cycle
Hi
the door lock is you problem. just replace and should be back to normal.
regards
Mar 01, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing machine door lock problem
I think service manual will be helpful to locate your problem .
If you need one let me know
Oct 02, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Kenmore Washing Machine
check the lock switch on the front load washer sometime it gets stuck
Mar 18, 2008 | Kenmore 44042 Front Load Washer
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
