Question about HP PSC 2210 All-In-One InkJet Printer
Hourglass symbol When I turn on the printer it makes some strained sounds and then I get the hourglass symbol and nothing else.
  • 2,785 Answers
Dear lund0448
there might be some hardware problem or may be obstruction in the way of the print cartridge carrier.better check it yourself by opening the printer or you send it for servicing.
Posted on Apr 04, 2008
What does The Hourglass symbol mean on a Samsung front load washer
The hourglass symbol usually means the machine is "Delayed" This might be because of a breakage or issue inside the machine. If this is not the case, check the user instruction manual
Oct 03, 2016 | Samsung Washing Machines
I have an HP PSC 2510 that has a permanent hourglass busy symbol showing. When turned off and on there is a grinding noise from the scanner transport mechanism which ceases after about 1 minute but the...
Looks like a faulty gear mechanism in your scanner. It is not able to return to the home position. You could try a hard reset: Unplug from power source and PC, wait about 5 minutes and try again. If the issue recurs, then you will need to take it in for servicing..
Jul 04, 2008 | Office Equipment & Supplies
I plugged in into my computer and just has an hourglass symbol on it
hi, an hourglass symbol indicates that it is loading or your computer is trying to access the unit. Hope this helps. goodluck
Jun 23, 2010 | Audio Players & Recorders
If your hourglass of death is occuring after a hard reset - Battery pull. It suggests a software issue.
You will need to reload your software, using desktop manager.
Mar 07, 2009 | RIM BlackBerry 8700g Cellular Phone
same thing to me but not off ebay when i first bought my 7100t all it would do was show an hourglass but i never used it for a month then i charged it then it worked fine
Jul 22, 2008 | RIM BlackBerry 7100t
Constant hourglass symbol-draining battery
Hi, this is called the hourglass of death, the device is stuck in a reboot cycle.
You will need to reload the applications, but you can't use Desktop manager because the device resets and the connection drops.
First make sure the BB is unplugged, then go to Program Files > Common Files >Research In Motion > AppLoader and run loader.exe. Click next, it will say port : COM PORT 1 now is the tricky part you have to plug in the BB and COM 1 will change to PIN: UNKOWN , when this happens you have to quickly click next before it reboots again, then it will ask for pin and now has an connection with the device so you can go ahead and re load all the apps.
Good Luck
Apr 16, 2008 | RIM BlackBerry 7250
Printer wont work!
get new printer drivers here first
install, then run a test page with printer disconnected from computer..
if that works, then reconnect printer to computer. should 'see' it, and proceed..
Mar 03, 2008 | HP PSC 2410 All-In-One InkJet Printer
Legend of Zelda - Phantom hourglass
<img src="" img>
draw an hourglass shape (like a figure-8 with a flat top and bottom) that starts from the top left corner (1), across (2), diagonally down to the left (3), across the bottom (4) and back up to connect with the starting point (1). If done correctly, the hourglass shape on the door will glow and let you through
Jan 12, 2008 | Nintendo Game Boy Advance Console
Unit wont start up after power failure
Answer on Search there to see how to lubricate rod under scanner glass. Common fault. Mine responded instantly starting up fine after rod lubrication which stops scanner initialisation routine and leaves you looking at hourglass.
Jul 30, 2006 | HP PSC 2510 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
106 people viewed this question
Ben Johnson
