Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Won't hardly spin
It won't hardly spin It suppose 2 spin fast
  • 750 Answers
Happymarried
You said,it won't hardly spin It suppose 2 spin fast
It sounds like a worn belt. Does it smell like rubber burning?
Or like the coupling connecting the transmission to the agitator is worn out!
If I were there hands on I could be definite.
But it sounds like you need this replaced!
Thank God it's not the transmission.
When a transmission goes out of warranty, it;s not worth putting good money into bad! They are just to expensive a repair!
Only a hands on laundry tech can make the diagnoses.
This time you should call service
Let me know what is the final results.
Please write me back.
How old is the washer??????????????
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You,
huuum
Please give me a good rating before you sign off.
Thank You
Posted on Sep 13, 2008
My bowl spins so fast that the ingredients flu out of the bowl
The bowl is not supposed to spin, it locks into the base of the pedestal. Engage the lugs and turn it one way to lock it up.
Mar 30, 2014 | KitchenAid Classic Stand Mixer
Twin 2 17 hp briggs stratton
It's harder to spin that what is normal compression ?
it's supposed to be harder with the plugs in. that's what creates compression
Aug 22, 2013 | Garden
Long spin, won't spin very fast
Possible there are two issues, one being that there is a friction on the drive, check manually to confirm on this fault.
secondly check on the motor circuit and motor, if there is less power during spin the RPM could be low.
Apr 11, 2013 | Washing Machines
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
Commercial speed queen won't speen fast enough clothes are still dripping wet I think its too sensitive is there an adjustment for that?
Try putting on a new drive belt. It may be that the belts are slipping and it won't spin fast enough.
Jun 27, 2011 | Washing Machines
How do we connect an m audio fast track pro to my pc and mixer (dp-01fx)?
All you have to do is to connect with 2 cables your mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 20, 2010 | M-Audio Fast Track Pro Mobile USB...
Have a ryobi rlt 30 cd and the spool wont spin fast enough
hgffggkgjgjgbTry taping the bottom on a hard surface;HARD!;;;;;;;bjjjjjjkjjjjm4454541joojojojlj That did the trick for me for some reason it doesn't grab and it gets lose were it won't spin fast bearly cutting a blade of grass.
Apr 21, 2009 | Ryobi 15" Electric Factory Reconditioned...
Won't hardly spin
the back and fourth motion is normal. we have a ge and it does the same thing. for the slow spin and burt rubber smell the drive belt is more than likely streched, the fast fix is to replace the belt. HOPE IT WORKS FOR YOU!
Feb 12, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
