Question about E-Machines etower 400i PC Desktop
Boot I just replaced the power supply. The machine wants a boot disc, but I don't have one. What can I do?
  • 145 Answers
You may try disabling booting from cd/floppy, but if there isn't a boot record findable on the hard drive you may have to create a boot rescue disc or may even have to reinstall your operating system.
Posted on Feb 12, 2008
HP Pavilion a1410n Disk Boot failure
After pressing F1 confirm that the master drive is listed in the boot setup program.. If the drive is not listed confirm that the electrical connection from the new power supply is correctly connected to the drive. Failing to correctly connect the hard drive during power supply replacements is most likely the problem. Also confirm the SATA connections to the drive.
Confirm that the drive gets warm and a slight vibration when power is first turned on confirming the disc drive is spinning.
Hope this helps?
backupsourceee-t0vwfcdnxxkr5mkphhbyx0tu-1-0.jpg These are typical screen shots that show the boot drive connected to the mother board MOBO detected during the initial boot process. Look for similar format in your machines boot setup.
Jun 27, 2017 | HP Pavilion a1410n (ER890AA) PC Desktop
T3830 wont power on
You might want to try a boot disk if you have one if not you can get one online at
http://www.tomshardware.com/forum/66822-63-free-windows-boot-disc-emachine-laptop
Apr 07, 2013 | E-Machines eMachines Desktop PC
My acer aspire 3000 wont boot! i have the black screen. whhat should i do
Try taking out the battery not the CMOS battery power cord remove from input of laptop press the power button to discharge. Let sit for about 15 minutes. When that is complete replace the battery and place the power supply unit and power laptop back on this may do the trick. Now if that does not get it to boot then try the recovery disc option when inserting the restore disc in. Or if Windows disc do a repair. It will assist you will the boot fix. Let the software do its thing.
If that does not assist you then you may need to have the notebook serviced to see what the problem is. It can mean a board matter or if the machine does turn on and you hear fans going or a fan it may be the lamp in the screen has gone out. So many variables involved here that it would be wise to have it checked out by a professional before messing anymore with this Notebook.
John
Apr 20, 2012 | Acer Aspire 3000 Notebook
My motherboard(ga-6cxc rev 2.0 motherboard) don't show any sign of booting but if i let some part lose it beeps(long) what should I do? even the keyboard don't light up(num lock...) and monitor...
Unplug all of your RAM, expansion cards and IDE/SATA devices. Leave only the processor and the CPU/heatsink plugged in, now try turning it on. If it boots, you should get a ram error, which is normal. If it doesn't boot, either the board, processor, or power supply is bad. Next, reinstall the RAM and start it up again. If it boots again, keep adding parts until you find the one that is causing the problem.
Hope this helps.
Sep 25, 2011 | Gigabyte Slot 1 GA-6CXC-1 Motherboard
Gateway zx4800-02 shuts down after 4 or 5 minutes
overheating would be my first guess my next guess would be a bad power supply but unfortunately there are many possibilities:( you could try booting the machine from a disc and this at least would tell you whether the operating system was corrupted or the hardware because if you boot from a disc and it still shuts itself off then it is a hardware issue. if you want more information about how to boot from a disc just ask:)
Jul 24, 2011 | Gateway ZX4800-06 (PWG8502023) 20 in. PC...
Non-system disk or disk error replace and stricke any key when ready that which in my black screen,what can i do? thank you kind regards
sounds like your pc is trying to boot from a disc drive without an operating system installed on it. I sometimes get this with my toshiba 1.5G external. Try turning off any non-booting drive connected to the machine and try again. If you don't have any external device connected then your system disc is either corrupt or dead and needs replacing or the operating system reinstalling.
Jun 24, 2011 | Kanguru - 500GB Disk (Black)...
Problem "don`t boot up" in
Check the power supplies. check power cord plugged in properly to the machine snug and tight recommend a tech from Konica Minolta
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 16, 2011 | Minolta Di2510 All-In-One Laser Printer
Emachine T5212 will not boot up unless operating system disc in used. Get direction to enter boot disc.
Restart, press DEL to enter BIOS and change the boot priority/sequence to boot from your HDD, second choice will be from CD-ROM and last from floppy. Next after saving the changes allow it to boot normally....sodeep.
Mar 21, 2009 | E-Machines T5212 PC Desktop
Unable too logg into the system
sounds like a hard disk issue try booting from the original s install disk . the see if you can reapir the installtion
if it still can recognise the disk you probably have a hard disk problem. Eithe buy or get a techical person to call out and check the hard disk for you.
if you have win xp boot to the cd then choose repair at the first menu , when you get to the dos screen type in
chkdsk /f and let it do what it must to complete.
hope this helps
Jan 02, 2009 | E-Machines Emachine T5026 power supply **...
Hardisk failure
It can be a few things that are causing your issue; try these tips and see if any work for you: http://kb.iu.edu/data/aelm.html
If they don’t at least post what exactly happens when you try to boot, and we’ll help you further.
Nov 11, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
E-Machines etower 400i PC Desktop Logo
62 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
