Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Faulty Memory Stick
At the moment when the memory stick isinserted into the computer - the light is not coming on - help - i need to retrieve the files as it's got all of my coursework on this stick!! Its not a Micro
Its a Cruzer Fleur 2GB
  • 3 more comments
  • Nimmy123 Feb 13, 2008
    Sorry Not A Computer Wizkid. Could You Simplify The Above. Btw The Computer Does Not Even Recognise The Disk
  • webby123 Mar 26, 2008
    hi can someone help ive gt a sandisk fleur cruzer 2gb memory stick it is farely new and has got all of my coursework on i have been using it earlier 2day nd now it does not recognise it in and the light does not come on in either of my laptops i have been ejecting it correctly plz can someone help!!!
  • zizie Mar 27, 2008
    i have cruzer micro 2GB USB. it just refused to work. The light does not go on when i stick it into the computer. I try it in all the computers at my school computer lab it still does not work .Please tell me what to do.
    ZIZIe
  • Anonymous Aug 21, 2008
    at the moment when the memory stick isinserted into the computer - the light is not coming on - help - i need to retrieve the files as it's got all of my coursework on this stick!! Its not a Micro
  • Anonymous Nov 20, 2008
    stick is inserted into USB port. No light comes on and computer does not recognize stick.
    help!
Ok ok..this 1 will mabe work...go controll panel administrative tools and device managment some thing like that...in the dignostik tools take the 3 option frome the second 1...in the left u will see the drive..mabe and hope u will...if u did see the drive than ur problem is not that bad...i canot tell u wat to do becose u mabe need a litle of cracking tools the easiyest way is go 2 google and search under live cds recovery and something lik eit or ghost live cd..dowload the file and burn it on a disk..enable ur boot frome cd rom in the bios setup menu and boot frome it..and u must go frome there..g luck
Posted on Feb 14, 2008
    Scholar:
  • 193 Answers
Use live cds and boot frome it u will be abel 2 access
Posted on Feb 13, 2008
What could have happened to my memory stick pro duo? I took pictures and was able to view them perfectly fine. When I went to deveolpe them I put the stick in the wrong slot that was too big. The sti
When you plug this memory stick into your computer and the computer cannot detect this memory stick then the memory stick is damaged and your photos cannot be retrieved.
Jan 06, 2013 | Sony 1GB Memory Stick PRO Duo Memory Card
I want to transfer pictures from my toshiba laptop to a memory stick can you help please thank you
Insert your memory stick to your laptop, if your laptop has a memory stick slot or in the USB slot (if it is supported). If it doesn't have on you need a memory stick card reader. Insert your memory stick on a card reader then insert the card reader into the USB slot.
After that your laptop will prompt you and choose "view folder".
Now go to the folder where your pictures is located and choose the pictures you want to transfer and then right click on it and click "copy".
Go back to the folder of your memory stick, right click and then click "paste".
That should do it.
Thanks for using fixya!
Update me if you still have questions and let me know how I helped you.
May 28, 2011 | Computers & Internet
Laptop freezes. Turn off. Wait. Turn on. 3 beeps. Small light on lid lock lights for about 12 secs then flashes 4 times. Cycle repeated.......No screen picture.
The most common cause of the '3 beep issue' is memory or RAM failure. Generally, only one memory stick goes bad (you only need one stick for your computer to work) so here's what you do:
Step 1: make sure the MacBook is off then remove ONLY 1 memory stick. After you remove it, place the battery back in the battery bay then try powering it on. If it works, you'll know that memory stick is failing and you can buy a new one fairly cheap.
Step 2: If step 1 didn't solve your issue, replace the 1st memory stick and pull out the 2nd. Replace your battery in the battery bay then power up. Usually one of the memory modules is bad. If neither step works for you, try getting a compatible memory stick that you know is working just so you can rule out both memory sticks being faulty. Here is my email adress: i_Patch,securepath@live.com Don't forget to vote if this helps you and good luck! Contact me if you have further questions.
Apr 18, 2010 | Computers & Internet
How to repair a memory stick duo turn that to raw
Put memory stick in camera and format it, this is the only way to fix some problem in memory stick.
If that does not help, memory stick got hardware problem that is irreparable. Buy new memory stick then.
Thanks.
Nov 05, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
Problem in formatting corrupt memory stick
Sorry to hear that but I reckon it ceased for good, at times their not 100% reliable but you can try using an adaptor with it via your PC to see if you can retrieve all your data’s but the chance is slim from experience, you might be looking to get a new one, if you did buy new one try backup it up from time to time via your PC or alternative storage so you can retrieve your data’s when your memory card come to a halt
Jun 25, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
No memory space in memory stick
You can delete pictures from the camera. You can transfer the pics to your computer, then delete. Plug you camera into your computer, click start/computer/ double click on the drive that accesses your camera. From here, you can drag/drop pics or delete them or format the entire memory stick. If you need all of the pics and do not have a computer, you will need to purchase another memory stick.
Please take a moment to rate my answer. Thanks.
Apr 28, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Memory stick cannot be detected
STICK LIGHT COMES ON AND STAYS ON COMPUTER SAID ITS DEFECETED. I had just used it
Jul 08, 2008 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
785 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
