It may be ovorheating, how often does it restart and under what conditions/loads? You may want to change your bios settings to the defaults and see if it helps, though you may have to reconfigure some settings there if it does work, also you may have a thermal readout in bios, you can check to see if it is too hot with this if you have it. Also you may want to try removing any extra ram you have installed, as it will lower the processor speed and in turn the heat generated. Be sure to also make sure your processor fan and heatsink are free of dust, this can make a huge difference.
