Question about Refrigerators
Water comes out dispenser when ice maker calls for water
This fridge is one year old. Ive replaced the water valves, water line, diodes and wiring harness. Now, when the ice maker calls for water, water shoots out the water dispenser on the front of the freezer door. The amount is about 4-6 ozs. Frigidaire has said its a bad water valve but we just replaced that a week ago. Any ideas?
  • coachgilbert Feb 12, 2008
    did that. same thing happens, except the water flow is greater when it comes out now. wasn't the wires.
  • Anonymous Mar 21, 2008
    I have the same problem with Frigidaire Refrigerator FRS26ZGGW4. Water comes out the in the door water dispenser when the icemaker cycles on, and if I attempt to fill a glass with water from the dispenser, water also comes out into the icemaker weather it is making ice or not. Runs into the ice cube storage bin and freezes solid so it makes it hard to get ice out the door. I replaced the icemaker - can't do that wrong, it only goes in one way and will only plug into the harness one way. I replaced both the single valve on the freezer side and the dual valve on the refrigerator side. TWICE. Can't do that wrong, either as they are color coded. Anyway, I have swapped the lines and wires and it didn't stop the problem. Now, some body said there is a "DIODE" on the wiring harness before it plugs into the dual valve on the refrigerator side. I looked, and there is some sort of a small copper or metal colored little thing in the wiring harness covered with a clear flexible rubber cover to protect it. WHAT IS THIS THING AND HOW DO I GET ONE AND REPLACE MINE? It seems to be made into the wires. Thank you all in advance.
  • 54 Answers
If the ice makers calling and its comming out of the doorthe valves are wired yhe wrong way around swop the wires from one valve to another. hope this helps
Posted on Feb 12, 2008
Ice maker water line comes loose when water turns on
Sounds like your terminal connections on the water valve have gotten reversed. Try switching them..Also you may need new water valve..
Aug 03, 2017 | Refrigerators
I have a GE Refriderator about 3 years old. Recently the water dispenser stopped working, and the ice maker stopped as well. The ice maker seems to freeze up as it dispenses water in the tray to make ice....
Are you having any cooling problems whatsoever, anywhere? Is there any area in the unit that you dont put food for cooling reasons? if cooling is fine, check the water pressure as it comes into the refrigerator, you wil have to disconnect the water line at the solenoid valve behind the fridge. If pressure is good, pour 4-8 oz of water into ice maker, does it eject those cubes within 24 hours? then replace your water valve(s) One assembly houses a solenoid for both the ice maker and the water dispenser, both solenoids are bad.
If you have further questions, visit my website and send me a question. www.FixMyFridge.net
Mar 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have an electrlux modelGLHS36EEB5 fridge.I changed the filter but the ice macvhine won,t start again even after pushing and hold the button for the colours
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
When your ice maker dumps and refills with water it will come out the water dispenser with the wires swapped. If it doesn't then I would have to blame it on the solenoid.
If the lines are the same size you can also swap them around to do this check.
Water inlet Valve
You can disconnect the line coming out of it and try the water dispenser to see if the valve is working. If it’s getting power it should click when you try it and water come out.
Feb 10, 2010 | Refrigerators
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Hi, I have a 9 year old TPS24TP. I can get water thru the door, but the ice maker does not make ice. I pulled it our of the enclosure and see that there is water in the lines going into the water feed, but...
Well there is a water valve on a lot of the fridges and that water valve has water doing to the dispenser and there is a water line from the valve to the ice maker. These two lines are separate and the ice maker valve can be bad. They are generally down towards the bottom of the fridge and can be replaced. You just have to trace down the water lines and see where they go. Here is a shortcut that may possibly have the drawings for your fridge and parts if you need them. http://www.appliancepartspros.com/partsearch/
Jul 27, 2009 | Refrigerators
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
NO WATER OR ICE AT DOOR OR IN ICE MAKER
This is Gene's solution not mine, for a Ge fridge.
Assuming the ice dispenser works fine, the first thing I would check is the water filter, then the water inlet valve on the back of the fridge.
If the water filter is more than a year old it will cause restriction to the water flow.
Locate the water inlet valve on the back of the fridge. Remove the wires from the blue solenoid and check for 120V coming to the solenoid while the water dispenser lever is depressed.
If there is 120V then the water inlet valve has to be replaced.
May 03, 2008 | Refrigerators
Water coming out door and into icemaker
welcometo the world of FRIGIDAIRE!! only company i know using that DIODE within the harness, im unable to lok up the part number for the DIODE kit, there are 2 of them, i would call the manufacture and ask them to supply you with number... just seems a ltiile wierd that ice maker fill troughdoor andyour water fill the ice machine, i see that you tried switching wires and lines still thesame result, please excuse the silly question but did you try to just switch the wires to the dual valve??? not worrying abouth the lines. just askin.
Mar 21, 2008 | Refrigerators
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
