Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Does'nt spin Fast
My washer doest'nt spin fast to get the extra water out?
  • 943 Answers
Hi .thanks for the question .i would look at the drain hoses. it could be that something could be caught, or a kink in hose. check that thanks the appliance doc . please rate me
Posted on Oct 01, 2008
Atf6000fs2 does not fast spin to remove water only slow spin /checked it on all spin speeds
Either the motor cannot turn over fast enough to power the pulley system, or there is an issue with the pulley system.
Sep 04, 2012 | Frigidaire Affinity ATF6000F Front Load...
Spins too fast
Check that the belt [under turntable] is`nt twisted or the 33/45 speed button is`nt sticking on 45rpm
Feb 26, 2010 | ION Audio iTTUSB Turntable
Whirlpool not spinning fast enough. Not
We had same problem which got worse. I had to take the tub out as it wasn't engaging on spin. I feel a washer
was left out at factory as it wouldn't tighten down.
After a few attempts I finally found a washer that was
right ( elec dept ). You basically take the whole thing apart.
It works now but we bought extra washers
Feb 12, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer will nt spin fast enough to drain all water out of cloths.
There's a good chance that the clothes are not spinning very fast BECAUSE they are too wet and heavy. The root of that problem is probably a blocked filter. I would suggest you check and clean your filter (Probably behind a door like the fuel flap on your car, situated in the bottom of the machine chassis).
Feb 02, 2010 | Kenmore Washing Machines
Spin is not going fast enough to dry out clothes
spin is not suppose to dry the clothes, simply wring the most water it can from them.
are you sure you are not set on a gentle cycle? might your washer offer a extra spin cycle?
Dec 14, 2009 | Computers & Internet
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
Apr 28, 2008 | Kenmore 44102 Front Load Washer
Whirlpool lhw0050pq washer will not spin
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Apr 25, 2007 | Whirlpool LHW0050PQ Front Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
51 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
