Question about Maytag MGR4451ADS Stainless Steel Gas Kitchen Range
Oven does not heat past 310 degrees
Have unplugged, checked troubleshooting in manual, tried different keypad controls. Error F14 showed up once. range is 4 years old. When I unplugged, the cord was noticeably warm to touch.
  • 15,935 Answers
F14 is a memory corruption on the Clock Module.
Replacing the module is your only fix.
It appears your Clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Nov 03, 2007 | Whirlpool GBS307PR Electric Single Oven
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
I have a maytag MER6772 electric rage and the bottom oven will not heat past 100 degrees. the top heat to 350 then's cuts off. I replace the Control board wahts next?
The board cannot function if the sensor is bad. You should always check a sensor first.themobilian_898.jpgthemobilian_899.jpgthemobilian_900.jpg
Use this chart to check the sensor.
This video shows how to check:
I have some manuals and error codes posted HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 15, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Duet GHW9150P Front Load Washer: what does the F14 error code mean?...
F14 = EEPROM Error
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU.
If there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights...
Your error code is for a stuck keypad. You can try pressing every button at random several times each to unstick.'
When the control board is changed on these ovens the keypad assembly is supposed to be changed also.
Nov 21, 2009 | Whirlpool Ovens
STOP WORKING WHILE RINSE & SPIN AND SHOW F14 ON THE SCREEN
F14 = EEPROM Error
Check CCU
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F14 error message
First change the fuse. Then if it still isn't functioning properly, you may have to replace the lamp, in which case you should contact a specialist. Details can be found in the Instructions Manual.
Go here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
and enter EB270 and click the Go button.
Then download the PDF file of the manual in English (EN)
Hope this helps :)
Chris (ziraffa)
ps Someone else on Fixya claims to have fixed the F14 problem by changing the PCB Board, whatever that is.. but there was no further rating or feedback given. That's all I have.. Good Luck!
Jan 11, 2009 | Gaggenau EB270 Electric Single Oven
Touch error
Your membrane keypad has probably failed.
If it is still under warranty, please contact the manufacturer's number in your owner's manual.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at http://www.microwavedisplay.com/keypad_replacement.pdf
We have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Essentially you unplug the oven from the wall outlet, and remove the control panel assembly as per the instructions at the site linked above.
(Remove the grille from across the top, remove the top screw in the control panel frame, then lift up & out).
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille.
Then unplug the keypad from the circuit board, heat up the keypad from the front with a hair dryer, then peel the old keypad off.
You have to make sure all the old adhesive is off or the new keypad will not stick.
I use paint thinner or mineral spirits, then follow up with isopropyl alcohol to be sure the panel face is squeaky clean and dry.
Then peel the backing paper from the new keypad and carefully press the new keypad in place.
You need to be precise - you cannot apply it, peel it off, then reapply it.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Jun 17, 2008 | KitchenAid KHHS179LSS Convection /...
Maytag MGR4451ADS Stainless Steel Gas Kitchen Range Logo
139 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
