Question about Philips PTV100
No UHF channels
I just got this from a friend and I'm only running with a roof antenna. I was able to set everything up perfectly. It recognized all the channels I receive but it won't display any of my UHF channels (23,29,41,45) even though it has the name/caption of the station displayed. Any thoughts? TIVO support said it has to do with the hardware, not their software so they referred me to Philips
  • 44 Answers
Sorry, looking up the Phillips PTV100, it does not support over the air broadcasting. Supports, cable and satellite reception.
The reason you are picking up The VHF channels (2-13) is they match cable channel frequencies up to this point. The UHF frequencies are not the same as the cable frequencies, even though the channel numbers seem the same.
Some other models or brands of TIVO may have this ability.
Posted on Feb 12, 2008
  • 2,336 Answers
I would suggest to check the VCR settings, It may be set for cable receptions and not OFF the air.
Go into menu and look for the ANT or Standard Channels.
Good Luck.
WHEN I PLUG INTO ANTENNAE--I GET " NO SIGNAL"---BUT I KNOW THAT THERE IS A SIGNAL BECAUSE I GET A PERFECT PICTURE ON MY SONY COLOR TV? HOW CAN I GET THE OLEVIA TO RECOGNIZE THE ANTENNAE SIGNAL?
You'll need to use the Olevia remote and press the MENU or SETTINGS button. The choose the SETUP or MEMORIZE CHANNELS option. MEMORIZE CHANNELS may be in an ANTENNA screen.
When you memorize channels you'll need to set the option for Antenna or Cable TV then have it memorize channels.
The television will run through each channel looking for signal and memorize those it finds. Sometimes it finds a very weak signal and you'll need to manually remove some.
Oct 04, 2015 | Sony Televison & Video
Channel 3 is only channel i get reception on my lg tv .How do I fix it .I have tried all the options on set up.
you are also spamming us,get an hd antenna and move it around in the open air above everything else and search for channels,do not move it while searching,if that doesnt work then you need to get the antenna i have that works great, 150MILES OUTDOOR TV ANTENNA 360 MOTOR AMPLIFIED HDTV HIGH GAIN 36dB UHF VHF
Jul 17, 2015 | LG Televison & Video
Hello, Well I have a Jensen antenna( Perfect for HDTV). How do I tune the antenna into a Soniq LCD TV Model E16Z10A. I can only get SBS channels and a few 9 channels. I have done everything! I need your...
I have the same problem with my soniq hd tv i got a digital antenna that plugs into the power and i have also tried the roof antenna and neither worked.. Could it be the tv?
Jan 01, 2011 | Televison & Video
I can't get FOX on my converter box--what is the channel # for FOX?
It could be your antenna. Some retailers sold consumers UHF-only outdoor antennas and not VHF/UHF combo antennas. Other outdoor antennas may not have a power boost included for the VHF antennas (rabbit ears). The new DTV signals from stations are now broadcasting in lower power signals than before June 12.
Outdoor Antenna
KMSP/FOX 9 and KARE 11 both broadcast on VHF signals. WCCO and KSTP broadcast on UHF signals. You will need a VHF/UHF outdoor antenna to pick up KMSP and KARE 11 and also get all the other channels.
Indoor Antenna
Check your antenna to make sure it's a UHF/VHF antenna. You may need an indoor antenna that has rabbit ears -- that is the best way to get KMSP/FOX 9 reception on your TV. Your antenna should have a power boost to amplify the VHF signal if you are having trouble getting FOX 9 or KARE 11.
What Antenna Is Right For You?
Need help locating the proper outdoor antenna to receive your local television broadcast channels? Based on geographical maps and signal strengths, AntennaWeb.org locates the best antenna for you, whether it's a home satellite system, high-definition television (HDTV) or a traditional analog set.
Make sure you antenna is pointed toward Shoreview, where FOX 9 transmits from.
CALL FOX 9 FOR HELP: 952-944-9999
Apr 07, 2010 | Televison & Video
Sk-32h240s unable to get all local channels thru ant. only what whould be the formally vhf channels, not uhf.
UHF needs a UHF antenna most all channel antennas do not work good on UHF,
Try the set at a friends house that does get those channels. UHF is harder to get and that is why a UHF only antenna is needed by most people. Lots of antennas are junk do a search and you will find the 8 bay C/M is rated the best by a large margin.
A good antenna amp at the antenna is also needed it should be a low noise one. A search will show the ones that work best.
The Gov. as much as lied to us and the TV Stations the type of digital they forced on us is the wrong one and millions of people even with a great antenna have lost TV.
Oct 25, 2009 | Westinghouse SK-32H240S Television
Digital channels
It's possible the stations you have in your area
have switched from UHF to VHF or vise-versa
I had the same problem and have lost one channel completely
You didn't clarify if your using an antenna or
cable qam so I assumed you are using antenna.
Youll need to check your antenna to see if it
supports both UHF vhf if it only supports one
that could be your problem .
go to antennaweb.org it will help you determine
what stations are avalible to you .
Jun 13, 2009 | Sanyo DS27510 27" TV
I bought a 32" conia tv and i cant get good reception! i have bought a amplified antenna and a hd set top box and still no good reception. my other tv's in the smae spot have had no reception issues....
well it's the same as the days of old, the antenna has a range of reception. the further the sations antenna, the lager your antenna must be. just because you bought an amplified antenna does not mean you will receive the deep fringe station. also the antenna must be UHF and VHF to receive the broadcast in digital. most of the braodcasters have gone with the UHF band because it is more stable for the bandwith of digital broadcast. the UHF band is very directional as well, so you must be pointing to the broadcasters antenna. no set top antenna will work if you are further than 15 miles of the broadcasters antenna. the roof top UHF/VHF antenna with a preamp is the way to go. I have tested every compact antenna and unless you live in the city that the broadcast generates you will get no reception with these. terks are junk, and any small amplified antenna does not work if you are in low lying areas. roof top, roof top,.....ROOF TOP!!!!!
Apr 24, 2008 | Televison & Video
No uhf with antannae
UHF channels are basically "line of sight" type signals. You need to be pretty near those UHF stations.
You need a Uhf or combination Uhf/ Vhf antenna to receive them - - Usually an out-door type.
Your TV needs to be set in the "antenna" mode to tune beyond channel 13 "air type" channels. Channel 14 is the first UHF channel if you're in the antenna mode. If you're in the "Cable" mode then channel 14 is a cable channel which is operating at a different frequency from UHF.
I hope this will help you!
Stargazer
Mar 21, 2008 | Orion STV2763 27" TV
Antenna problem for chanels 13-66 on uhf for newer hiatchi flat screen 52"
In the menu, the antenna setting needs to be changed from cable to antenna and then auto-programmed. The VHF/UHF section needs to be turned on. I'm not in my shop, but, I think in most Hitachi sets, this adjustment is in the "channel" portion of the menu. If you need more information, reply to this post and list the model and I will give better direction.
Sep 09, 2007 | Televison & Video
Reception of vhf/uhf channels
You did not mention which set you have, so look for a small switch (usually on the back of the set) or go into the menu and set the TV to the "broadcast" or "tv" mode. If the set is in the "cable" mode, you will not get any UHF channels above 13.
Sep 01, 2007 | Televison & Video
Philips PTV100 Logo
178 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
