Does it smell like raw kerosene or exhaust. If it smells like kerosene it sounds like you may have a fuel leak. If you can remove the grill, look inside and check for any kerosene in the bottom and in the tray under the heater. You should also check your fuel line for leaks. If it smells like exhaust look inside and on back of the heater for any black soot marks. There are a couple of o-rings, 1 in the exhaust connection in back of the heater and 1 in the flue pipe where the exhaust from the heater connects. There's also several gaskets in the combustion chamber that could be leaking. Hope this helps. If you need any more info, you can send me an email ([email protected]).
