Question about Canon PIXMA MP130 All-In-One InkJet Printer
Problem printing black
I have a problem printing black with canon pixam mp130 i clean the nozzoles but the black table return blured some lines are missing although i clean the nozzole over and over again what can i do ? thanks
  • 47 Answers
You will most likely need to clean out the wasted ink from the cartridge area, this will be a time consuming and fiddly process.
You will also need to clean the heads of the printer with isopropyl alcohol.
if you want to go ahead let me know and i'll walk you through the process although you will end up covered in ink and would most likely be best off getting this done professionally
Posted on Feb 18, 2008
The black ink in my mp258 canon printer is blured how can i fix it
Try a few print head deep cleanings if that does not help then you could try soaking the print head in a shallow plate of hot distilled water. Soak the tip of the print head only in no more than 1/8th to 1/4 inch of water.
Jan 16, 2013 | Canon MP250
Canon pixma mp130 service error 5100 - won't print
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
Dec 17, 2010 | Canon PIXMA MP130 All-In-One InkJet...
When printing all black areas have vertical lines going through ,have cleaned print heads and changed toner - no change in quality.
Clean the encoder strip, the clear plastic band that runs behind the print carriage. A Q-tip damp with alcohol will wipe off any grease or ink. You'll find a grease spot just above the area on your print that has the vertical line.
Jan 15, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Canon Pixma MP130 printing lines through pictures etc
I'd say it's probably the printer driver. Uninstal and reinstal it or update it. Printer drivers are a comon cause of printing faults.
Aug 16, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I have a canon pixma mp130 and it keeps saying cart. jammed
Press menu to maintenance.....go to cleaning roller....repeat cleaning 3 times....return to copying...hope this helps
Aug 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Won't print in black.Colour is fine though!
your printer black cartridge is demage buy a new one
Jul 24, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Improper printing
Clean the cartridge or replace it.
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Oct 27, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Printer update
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head. NOTE:
a. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
b. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
  1. Press <COPY> or <PHOTO>.
  2. Press <Menu> repeatedly until <USER DATA> appears.
  3. Press < (left arrow) or > (right arrow) to select [MAINTENANCE].
  4. Press <OK>.
  5. Use < or > to select [CLEANING] or [HEAD REFRESHIN] as necessary.
    [CLEANING]: Performs normal print head cleaning.
    [HEAD REFRESHIN]: Performs deep print head cleaning.
  6. Press <OK>.
  7. Print a Nozzle Check Pattern to see if print quality improved.
    4. Press <OK>.
    5. Press <OK> again.
      The machine prints a nozzle check pattern (A).
  8. If broken or white lines appear in the pattern, perform two Head Refreshings (from steps 1 through 6) then print another Nozzle Check Pattern.
  9. If print quality does not improve after two Head Refreshings, replace the appropriate ink tank.
Confirming The Nozzle Check Pattern
Broken lines
sj402061.jpg White lines
sj402062.jpg Click here to return to step x to perform Head Refreshings
Oct 18, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
63 people viewed this question
old marine
old marine
