Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Power cord retrieval
My power cord gets stuck,how do I access the recoil mechanism to free it up.
  • 1 more comment
  • kcert Feb 13, 2008
    Dear reddevil6, I managed to fix the cord , finding two screws after taking off the cover,these two were under the hinge.but would not let me remove the recoil cover,I could not find any other screws to release the cover completely,I was able to pry the recoil cover back enough to access the mechanism.If there is a way to get the recoil cover off completely that I missed I would appreciate knowing how.Thanks a bunch for your help
  • kcert Feb 14, 2008
    Dear reddevil6, I loosened the two screws under the hinge and tried to pull up the back,but it wouldn't budge only the front of the cover can be lifted a limited amount ,maybe I misunderstood ,am I supposed to force the front of the cover up?I have been afraid to put too much force and break it. the model # is116 2491290.Also I won't know the reason until I can get into the recoil area ,but since I freed up the cord it will not rewind. Thanks again for your help.
    Thanks so much you have been a huge help ----Klaus
    President:
  • 1,673 Answers
Depending on which model you have, take the bag door or lid off by pushing it back and it will unhook and come off, there are 4 screws that hold the cover on over the where the cord rewind button is, take that cover off and you can get to the cord reel.
Posted on Feb 12, 2008
  • 1 more comment
  • Lauren Junge
    Lauren Junge Feb 14, 2008
    Some models had 4 screws and some only have 2. The ones with 2, you push the back of the cover up and it should keep going up until it is off. To put it back on you have to push the back of the cover in until it goes on the inside of the casing. Then push it all of the way down. If you still can't figure it out, get me the complete model #, it will start 116.********
  • Lauren Junge
    Now that I see what model you have, You can force the cover back until it comes off. Then with a flat blade screwdriver, the (#1) part across the back, pry up until it pops off, then you can get to the other 2 screws.
  • Lauren Junge
    You are most welcome.
HOW TO REPAIR THE RECOIL POWER CORD ON A KENMORE MOD 116.23613300 VACUUM
generally you need to replace the spring mechanism. contact the manufacture for parts/cost. Most local shops don't carry parts to repair vacuums, unless it's a new model, most vacuums are designed to work until they don't then you replace. unless you spend more than 400-500 bucks on it that is.
Nov 25, 2014 | Kenmore Vacuums
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    The retractable cord is stuck all the way out and will not go back in. Is there a simple way to fix this "disaster"??? without taking vacuum apart that is. And this is not my exact vacuum but I...
    You have over pulled the cable out way beyond the limit marked on the cable, try gentle tug/ pull with. Thumb of the area around auto,rewind area may just set it in motion again. If no go you will have to bite the bullet and dismantle the hover auto rewind unit carefully noting how you take it apart ref, to any springs recoils mechanisms where and how they are fitted a photo or photos should help you reassemble the unit, go careful try makers Webb site may be helpful diagram ect.
    Oct 23, 2017 | Vacuums
    Have just purchased vax c90 vacuum cleaner,have a problem re-coiling the power lead.have followed instructions to press down on designated button,but power lead does not recoil.
    On pressing the cord has to coil into the holder and if this wont happen there is some mechanical fault in the recoiler or spring.
    You can pull the power cord once again outside and let it slide inside, repeat this sequence to allow the winder to respond and then it might pick up.
    Apr 06, 2011 | Vacuums
    I can't recoil the electrical cord. What do I need to do?
    Open the bag door, remove the bag (leave door open)and then with a hammer and a blunt instrument(wooden dowel) Strike the side rubber "bumper" rails towards the open door side of the machine from the back of the vacuum. You should get it started and then it should easily pull out from both sides. you can remove the bottom of the vacuum and remove the cord "guard" to allow the cord to go thru also. The back is held on by the union of these two halves by dowel pins(plastic nubs) Sometimes the "spring" mechanism gets jammed from over pulling. Just simply roll the smaller wheel to retract the cord manually. You could try spraying the rollers with a silicone or graphite type spray to allow free movement of the spring. Hopes this helps. WFServices
    Jun 25, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
    How do I get at the power cable recoil mechanism on a Dyson DC02 Standard Cyclone Cleaner?
    Go to www.dysonmedic.com then scroll to the bottom of the page and click on "DC02 cable replacement". You will find detailed instructions AND pictures! Can't do better than this.
    Aug 10, 2009 | Vacuums
    Dead Miracle Mate Vacuum cleaner
    You don't have to open the cannister. You can easily remove the black plastic collar through which the cord is supposed to emerge. The collar has a little springy tab that holds it in place. Once the collar is removed, you can reach in and grab the cord and pull it out.
    Steve
    Aug 02, 2009 | Vacuums
    Automatic Cord Rewinder is not rewinding anymore
    I had the same problem - the power cord for my Hoover Elite Upright (U5507900) was stuck a few inches out and wouldn't go any further. But when I unscrewed the rewinding mechanism, the cord had clearly gotten twisted and partly buried under itself so after some work I was able to free it. Now it seems to be working fine, at least for the moment. Note that I had to use small screwdrivers to unscrew the cord rewinding compartment, like the kind of screwdrivers you use for computer repair.
    HTH!
    May 27, 2009 | Hoover Elite Rewind Bagless Upright...
    Power cord recoil
    Well, there were two problems, the first being that the cord got jammed and I did not know how to get inside to clear it up. Finally we got under a dark gray cover which exposed screws which I was able to open everything up and fix it.
    Then the motor for the brush stopped working. We kept playing with it and it intermitantly operated. Obviously a connection that opened up from time to time. I may need to get another vacuum. I cleaned all the obvious connections.
    Jul 20, 2008 | Kenmore 22812 Bagged Canister Vacuum
    Electrolux Oxygen 3
    Most cord reels have a stop on it, it is a rubber wheel and when dust gets on the wheel, they won't always stop the reel. It would have to be opend up to get to the cord reel, then you could clean it out.
    Jan 12, 2008 | Electrolux Z5935 Bagged Canister Vacuum
    Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
    624 people viewed this question
    Top Kenmore Vacuums Experts
    Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
