Just a bad door switch. Turn the unit off, remove the upper grill, then remove the cover over the switches. there are 2. 1 with a black backside, and one that is all white. you want to replace the all white one with a new all white one. it just has 2 wires, doesn't matter what order they go in. pull em off and pop that thing out, then snap the new one into place. all of this should be done with the power off and the door open. Good Luck!
Hello, A leading cause of so many problems with Sub-Zero refrig's is the coil behind the top grill above the doors is clogged with dust. You can use a vacuum with a hose to clean that coil by removing the grill and cleaning it. To clean it remove the grill by removing the screws that hold that grill to the upper door frame where the grill attaches to the door frame and unhook springs from back side of the grill so it can be taken off to clean the coil.
I had the same problem with my sub zero. I took off the grill on the top and vacuumed the coil that has the fan in front of it. The problem has not happened since. I'ts worth a try.
Try GOO Gone in either the liquid spray or the gel. This will not remove anything like paint or things like that. You can also use this on your cars finish and will not hurt it. So you are good to go
Go to Sub Zero.com and click the showroom locator on the top left of the screen. This will take you to a locator to find the authorized parts distributor for your area I believe the part number is 3060140 have themm check it using your model and serial number. . Once you have the part remove the three phillips head screws that hold the grill in place this is assuming you don't have the louvered grill. There is a grey power cord with a white quick connect seperate this or turn the power off at the circuit breaker. You will be working on live electricity if you don't.Not good for your life expectancy. There is one more phillips head screw for the cover of the two switches. The light switch has a white back and the fan switch has a black one. Remove the two wires then push it down and slip the new one in. Replace all that you took off. While you have the grill off vacuum the condensor.
