We are perplexed because suddenly our water line would not give
any water. The ice maker still works. Is this a problem that we can
fix, and if so what are your suggestions? Thank you!
Marcie in Florida
Ours did the same thing, it ended up leaking from the hose in the back of the fridge it had broke andinstead of the water coming out of the front it was pouring out from the back, we diddnt notice it till the water made it out to the front of the floor. The ice still worked at the time. My husband was able to just cut the hose after the break and hook it back up to the copper hose and we were good. It has happened three times in a few years.
The ice maker and dispenser are on different water valves check your water filter first slowly push in your dispenser paddle and listen for a click then hum look at the bottom of the freezer door after removing the kick plate check to make sure the line there is free and not kinked if all that's ok replace the water valves
ice maker making and dispensing, but no water dispensing, changed filter and still no water.....
KitchenAid Superdud
