Question about Xerox WorkCentre M20i All-In-One Laser Printer
Problemas a Imprimir, recuadros y lineas
Al imprimir en Xerox m20i , en un reporte no imprimie los recuadros y lineas que se muestran en preview
  • 2 more comments
  • jda021 Feb 12, 2008
    the printer is new
    when printing a report of the system, single prints the text, but not
    the box and line
    need a extra configuration in the xerox m20i???
  • Anonymous Mar 16, 2014
    imprimir en formato espejo
    President:
  • 2,072 Answers
Sounds like a dirty seal glass. Clean the glass on the left side of the scanner. The 1/2 inch strip of glass.
Posted on Feb 12, 2008
  • 2 more comments
  • Rick Kasper Feb 12, 2008
    Explain the problem in more detail then.
    Do I understand correct you are getting lines across the page, I may have mis read the information.
    The responce is also not imappropriate. I am trying to help you.
    What I would try is this. Turn the machine off. On the back of the machine there is a 4inch by 4 inch panel, it has 2 tabs on it. Press those tabs and remove that cover.
    With the machine off, remove the 2 memory sticks from the slots. Please note where each is. They do need to go back into the slots they came out of. With the memoies out of the machine, turn it back on and let the machine come to ready.
    Once it comes to ready, shut it back off and reinstall the memory sticks in the proper positions and turn the machine back on. What you have done is reloaded the software and eliminated corruption. Let me know if that helps.
    You may want to try going onto the Xerox.com site and loading the newest machine firmeware onto your machine, It would be under drivers and downloads under the M20i and would be version 3.2.
Como soluciono el error B200 de la canon MP250
De acuerdo a lo que lei en un foro esto se produce por recalentamiento del cabezal al imprimir con un cartucho sin abastecimiento de tinta, tienes que cambiarlo o prueba con desintalar la impresora del windows y lo reinstalas despues.
Aug 30, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
Tengo una i,presora HP P4015n y ne sale un error 49.FF04 error turn off then on, como soluciono este problema?
Tengo un problema con la i hp 4014n, de repente empezo a imprimir los documentos con partes en blanco o imprime algunas partes otras no... marca error y no se puede imprimir el documento pero lo imrpime igual solo q con este problema
Sep 19, 2011 | HP LaserJet P4014n Printer
A quien corresponda, tenemos el equipo HP Photosmart C5180 All-in-One, que presenta el siguiente problema: cuando se enciende, no termina nunca de iniciar el menu en el Display, se reinicia continuamente,...
Hola este problema, también lo estoy sufriendo... encontre la solución aquí, http://h30434.www3.hp.com/t5/Other-printing-questions/Photosmart-C5180-Power-Up-Power-Down-Problem-Loops-on-off-on-off/td-p/132152 son los foros oficiales del servicio HP, al parecer no se hacen responsables, es un fallo que ocurre a bastantes usuarios. Según comentan otros usuarios se ha de realizar la sustitución de unos condensadores, leer las 4 páginas del post. He dejado la impresora unas 3 horas aproximadamente en el bucle dichoso y finalmente ha arrancado. Igualmente en ese mismo post viene como hacer un reset a la memoria de la impresora.
Un saludo y espero haber servido de ayuda.
Mar 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
Imprime las facturas pero no los albaranes
Esto parece ser un problema de software mas que de la impresora. Si el documento a imprimir contiene graficos (Codigo de barras u otros), es posible que no tenga la configuracion correcta. Recomiendo proporcionar mas informacion al respecto (Que programa usa, tiene el manual de la impresora? Trabaja en Windows o msdos, etc)
Nov 23, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Tengo una hp photosmart c6280 y tiene un problema con un error 0xc18a0001 compre los cartuchos nuevos y sigue reflejando el mismo error, compre un sistema continuo y sigue dando el mismo error,quiero saber...
if you speak english and can read english go here and scroll down to Re: hp photosmart 8250 by Anonymous (7/26/08 2:04 PM) reply There is also help from HP support online chat
http://www.fixyourownprinter.com/forums/printer/51559
si usted no habla Ingl?s o leer aqu? es la conversaci?n que le dir? c?mo resolver el problema paso a paso de este error. si esto no ayuda usted puede ir a CV y obtener ayuda en l?nea o hablar con un t?cnico por tel?fono.
Aceptar que ten?a el c?digo de error CV 0xc18a0001 problema y aqu? est? la conversaci?n que tuve con el ..... James Cowan tecnolog?a: el c?digo de error CV 0xc18a0001 llamarse Ernesto: Voy a ayudarle en este sentido James Cowan: gran llamarse Ernesto: Yo entiendo que una c?digo de error con 0xc18a0001 con "Error de sistema de tinta" se muestra en el panel frontal del dispositivo Todo en Uno de la impresora. En lo correcto? Soy James Cowan: correcta Ernesto: Gracias por la confirmaci?n de llamarse Ernesto: ¿Me puede dar el n?mero del modelo del dispositivo Todo en Uno que est? utilizando: James Cowan c6250 llamarse Ernesto: Gracias por la informaci?n. Gracias Ernesto: James, por favor h?gamelo conocer la temperatura ambiente en el que la impresora se sustituye James Cowan: 67 grados F llamarse Ernesto: Muy bien llamarse Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora para resolver el problema de James Cowan: puede llamarse Ernesto: Pulse la tecla "flecha izquierda" . Presione la tecla "Setup" clave y suelte ambas teclas, la pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte el bot?n "Aceptar". llamarse Ernesto Por favor, ignore los pasos anteriores, James James Cowan: ok si nada parec?a hacer nada Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora Earnest el: Pulse y mantenga oprimido el "Imprimir fotograf?as" y "ojos rojos" botones. Suelte ambos botones. La pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte en la secuencia de "ojos rojos", "Imprimir fotograf?as", "ojos rojos" Ernesto: la pantalla debe decir "apoyo" y mostrar el rev FW (algo as? como R0616R) James Cowan : Ernesto COxxFN0723BR: Bueno Ernesto: 2. Pulse y suelte el bot?n de flecha derecha hasta que la pantalla dice "Men? de configuraci?n del sistema James Cowan: puede llamarse Ernesto: 3. Pulse y suelte el bot?n "Aceptar". James Cowan bien y que dice llamarse Ernesto estado de fallo de hardware: pantalla debe decir "error de estado de hardware: Despejado. Pulse Aceptar para borrar". Llamarse Ernesto: Pulse y suelte el bot?n "Aceptar". Mensaje se convierte en "estado de error de hardware aclarados continuar. Pulse Cancelar para":. Llamarse Ernesto Pulse y suelte el bot?n "CANCEL" tantas veces como sea necesario, de modo que, ya sea el "Welcome to Photosmart Express", aparece la pantalla, o bien, la tinta " El fracaso del sistema "aparecer?. NO TRATE DE NO ESCRIBA EN ESTA ETAPA. POR FAVOR James Cowan: puede llamarse Ernesto: Con el bot?n de encendido, apagar la unidad y desconecte el cable de alimentaci?n de la parte posterior de la salida de la impresora y la pared:. Llamarse Ernesto D?jame saber una vez que se realizan con el los pasos anteriores James Cowan: ok su desenchufado llamarse Ernesto: Espere 30 segundos para que el poder ser dado de alta ya continuaci?n, conecte el cable de alimentaci?n al enchufe de la pared primero y luego en la parte posterior de la impresora llamarse Ernesto: Encienda la unidad. La impresora puede mostrar mensaje "USO DE ENERG?A BOT?N DE PARADA DE LA IMPRESORA" seguido de "Pulse Aceptar para continuar". Pulse Aceptar. James Cowan: puede llamarse Ernesto: Quisiera saber el mensaje que muestra en la parte frontal del panel de la impresora James Cowan impresora: preparaci?n ocurriendo - no interrumpir Ernesto Bueno James Cowan: puede hacer su Earnest: Vamos a imprimir una p?gina de autoprueba de la impresora ya James Cowan: tratar bien llamarse Ernesto: 1) Carta de la carga, A4, o de plano no utilizados legales, papel blanco en la bandeja de entrada 3. 2) Aseg?rese de que la impresora est? encendida y cargada sin usar con papel blanco), papel. Pulse Configuraci?n. El men? de configuraci?n. 4) Pulse el bot?n flecha hacia abajo para seleccionar Herramientas y, a continuaci?n, pulse Aceptar. 5) Pulse la flecha hacia abajo para seleccionar Auto-prueba de informe, y pulse Aceptar. El auto-informe de prueba imprime. James Cowan se puede imprimir llamarse Ernesto: Muy bien, por favor, compruebe si todos los colores pritned perfectamente en la p?gina de prueba James Cowan: perfecto llamarse Ernesto: Gran .. Saludos James Cowan:! Muchas gracias Ernesto: James, ahora usted puede seguir utilizando la impresora de llamarse Ernesto: Le agradezco su esfuerzo y paciencia para tratar de resolver el problema.
Oct 01, 2010 | Office Equipment & Supplies
Que controlador debo descargar, o que parametros debo modificar para que la Ricoh Oficio 3245c me respete los parámetros que por defecto establezca para impimir con un aplicativo en Foxpro 6.0 ?
El programa se adapta a la configuración de la impresora en cada momento. Si, por ejemplo, se diseñó un informe para formulario tamaño A4, al momento de imprimir se debe configurar la impresora para ese tamaño de papel. Esto se hace desde Panel de Control, Impresoras, y en la predeterminada se ingresa por propiedades. Se debe establecer el tamaño de papel en A4 si, por ejemplo, está establecido por defecto en tamaño Carta. Desde un programa VFP se puede utiizar un comando para que, antes de imprimir el informe, muestre las opciones de impresión a fin de que el usuario pueda modificar, por ejemplo, el tamaño del papel: REPORT FORM MiReporte TO PRINTER PROMPT
Saludos cordiales
Sep 24, 2010 | Manuel Esteban Je joue e Kraland
Tengo un problema con la impresora kyocera fs-4000dn, que me sale el mensaje llamar servicio 7410:0052827, me gustaria saber a que se deve el problema. saludos...
tengo un Problema con mi empresora Kyocera FS-4000DN Laser Printe. me aparece comprobar caja de toner y no me deja imprimir les ruego q me colaboren muchas gracias por los servicios
Sep 23, 2010 | Kyocera FS-4000DN Laser Printer
LA PANTALLA SE PONE COMPLETAMENTE NEGRA CUANDO ENCIENDO EL AIRE ACONDICIONADO Y SOLO SE ESCUCHA
Dependendiendo donde vivas, y si esto solo ocurre cuando enciendes el aire, es simple que la misma linea que alimenta el aparato de aire acondicioneado, es la misma que esta supliendo energia al TV. El area donde vives debe tener problemas con caidas severas de voltage. Los equipos cuyo consumo de potencia es menor que la inmensa demanda de potencia que requiere un acondicionador de aire, tienden a llevar la peor parte del sunministro electrico. Te recomiendo que busques otro toma corriente para suplir el TV, y para estar seguro de que lo estas colocando en una linea que no esta con el aire, sin encende el aparato de aire acondicionado enciende el TV y ve te a la caseta de breakers, ve bajando (off) uno por uno hasta que veas que el TV se apaga, ponle una matrca a ese breaker ya que es el mismo que suple el aire. Luego conecta el TV a otro tomacorriente y repite el proceso (asegurate tambien de que la nevera esta apagada) si ves que en un breaker diferente al que marcaste hace apagar la tele, entonces dejala en ese toma corriente y con todos los breakers arriba (on) enciende el aire acondicionado) si no sufre la tele, ya resolviste el inconveniente, pero si se vuelve a poner negra, busca un multimetro o tester y asi con el aire funcionando, pon el multimetro en la funcion de voltage AC (voltage alterno) Y mete cada uno de los terminales o puntas del multimetro en un tomacorriente (no hay peligro alguno, el multimetro solo mide) deben haber 120 voltios aproximados con un descenso s ascenso de un 10%, es decir entre 108 a 132 voltios. si baja mucho menos el valor de lo que especifique, entonces tienes un serio problema con la energia que te suministran a tu casa. Si eso ocurre, me escribes y te doy una pequeña solucion a eso...
Dec 29, 2009 | Televison & Video
Hola que tal!
Hola,
Tu pantalla tiene 2 sintonizadores, por que no intercambias tu antena y pruebas si de misma forma la falla se sigue comportando, o por lo menos cambia... ejem: que ahora falle el recuadro mientras que el principal ya no. De ser asi, acorralamos en mucho la falla en el sintonizador ya que un sintonizador es primario y el otro es secundario para funcion recuadro.
Prueba y me dices aprovecha, en este momento tengo una identica a la tuya en servicio!!!!
Si resuelves el problema, no olvides calificar mi asistencia
saludos y suerte.
Adonisito
Mexico
Mar 13, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
127 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
