Home | Pentax | K10D Body Only Digital Camera | Pentax K10D won't wor...
Pentax K10D Body Only Digital Camera
Problem for Pentax K10D Body Only Digital Camera
Pentax K10D won't work with lens from Pentax K100 (film0
By Moni10 on Feb 12, 2008
I just bought a Pentax K10D and it shoots great pictures. I also have an old Pentax K100 film camera and when I tried to use the lens from the old camera on my new k10d the camera wouldn't work. The lens seemed to screw on properly, but I couldn't get the shutter to work. Do I need an adapter?
Solution #1
posted on Sep 10, 2008
Not Rated)
E-man_1
Rank: Wiz
Rating: 80%, 23 votes
The lenses are probably manual focus lenses,
  1. Make sure that the apature ring is set to 'A' or automatic,
  2. if these are manual focus lenses then switch the focus switch on the left side of the camera body to MF
  3. If this still doesn't work, or you are having trouble with the apature ring then press the menu button to go to the  menu then press the right arrow key untill you are in the  Custom Settings, scroll through the custom settings with the up and down arrow keys until about the 2nd from bottom there is an option called "using aperture ring" set this to 2 (Permitted) This will make the camera take a image when lens is on any f-stop manually.
Try this and everything should work fine. If all this hasn't worked then try seting the mode dial on the camera to M manual mode. Cheers
Was this helpful?
Yes
No
Popular Solutions for Pentax K10D Body Only Digital
Questions and Unsolved Problems for Pentax K10D Body Only Digital
Do you recommend Pentax K10D Body Only Digital Camera?
Answer
Answer
Ocassionally the camera will not show a picture - it shows as all black on the card. It may shoot 10... (More)
Answer
where can I purchase the bottem plate for my k10d camera. Mine got cracked while on vacation.
Answer
I can take photos but, the auto focus is not working
Answer
I have a Pentax K10D camera with Pentax lenses and 10% of the time the pictures turn out very green.... (More)
Answer
I have a 75-300MM pentax lens for my Pentax DSLR. My other lens works fine. The telephoto lens... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pentax K10D Body Only Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
