Question about HP OfficeJet 6110 All-In-One InkJet Printer
How to open bottom plate in HP OfficeJet 6110 All-In-Onebecause styrofoam is stuck in the roller. If you like you can call 732-679-3560
    Novelist:
  • 188 Answers
Hi Onkar,
Please click on the web link given below and perform the steps carefully to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00107909&cc=us&lc=en&dlc=en&product=79477
Posted on Mar 20, 2008
My hp officejet 6110 all-in-one carriase are stuck completely and cannot remove cartridges either my hp officejet 6110 all-in-one carriase is stuck as for left and want move at all
Try to power off and unplug the printer, then force the carriage to move with your hand
When the carriage moves, place it in the extreme right position, then plug in and power on :D
Aug 17, 2014 | HP OfficeJet 6110 All-In-One InkJet...
A small piece of paper is stuck in the rollers. How do I get it out?
open the door back of your printer and remove it from there
by pulling it out
If i helped you pls vote me
Oct 11, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Roller squeal? HP OfficeJet 6310 all in one series
It could be the chrome plated shaft the cartridges ride on. Lube with oil.
Mar 10, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Need feed rollers for a hp officejet 6110, printer not scanner
If you can get to the feed rollers, take a Scotch Brite cleaning pad(green, used to scrub dishes) and put rubber restorer on it and hold on tight and try to feed a sheet. The rollers will spin no the pad, both roughing up the surface and cleaning the rubber. Other wise throw it away and buy a new printer.
Feb 27, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Paper jam message but no paper is jammed. how do i fix it (hp officejet 55210 all-in-one)
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 says there is a paper jam when there isnt
open the rear access door and clear the rollers,
Disconnect the power cord from the product.
Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
Jan 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Original document stuck in feeder of HP OfficeJet 6110 All-In-One
ok...this is not that hard...you'll need to open up the top of the machine, and most likely remove some components. Take a look at this link first though Got backup?
Feb 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110 malfunctioning
The paper sensor flag is probably stuck or broken. The part number is C7309-40013.
Dec 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
50 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
