Question about AmcorAire UCHW-H12AF2 Split System Air Conditioner
Fan Motor Replacment for YDK-16-4-L
Looking for a replacement for a YDK-16-4 L1 (120v, 3 speed) This is the fan for the condenser for an AMCORAIR A/C Unit
We had the motor go out on our unit. My father diassembled the blower while on the wall. He pulled the motor out and found that the bearings were cheap and unsealed. He replaced them with sealed and higher grade bearings from Grainger. He reassembled the unit and it worked. It sounds quieter.
Posted on Apr 02, 2010
  • 73 Answers
We have the condenser fan motors in stock:
ajk1956@msn.com
Posted on May 05, 2010
  • BRIAN KELLEY Jul 15, 2011
    Do you mahe a replacement Fan Motor for YDK-16-4-L. If so how much? Can you let me know, my # is 559-380-6418, or 559-420-8099 Marc or Brian
    mbradf@yahoo.com
    ajk1956@msn.com Do you have a replacement Fan Motor for YDK-16-4-L. If so how much? Can you let me know, my # is 559-380-6418, or 559-420-8099 Marc or Brian mbradf@yahoo.com
    New Friend:
The motors are stocked at a discount price from www.ptacsolutions.com
Posted on Jun 04, 2018
SOURCE:
Where do I get a replacement condenser fan motor
You need the RPM, VOLTAGE, HORSE POWER(HP) info. Any HVAC or refrigeration supply house may sell you one. Most are wholesale only but 1 should sell it but won't offer a warranty, just in case you don't know what you are doing and miswire it. Air conditioning parts and supply.
Jun 26, 2015 | AmcorAire UCHW-H12AF2 Split System Air...
I urgently need a air-conditioned condenser fan motor
Depends where you live you can contact united air conditioning this is a parts store. Grainger would have it. You need to have the horse power of the motor and the RPM of the motor and the amps. you will be able to find a replacement for it with this information. Be sure to tell them its a dual shaft motor.
Sep 10, 2014 | Heating & Cooling
My goodman cental air system is having problems. First, the blower inside (furnace) keeps running for hrs after the outside condensor shuts down. Now, the condenser blower motor wont operate at full speed....
the cause of your indoor fan running all the time or for long time after your heat pump has stopped heating is the fan delay relay. It has welded its internal contacts together. If you take off the side below the control panel, the fan delay relay is normally mounted on the header where the fan discharges. Good news, the fan delay relay are fairly inexpensive and easily to change.
As far as the condensing fan motor not running at full speed, when it was changed, did the technician install the correct fan motor. Most condensing fan motors are either 875 rpm or 1175 rpm. They are exactly the same size and if the technician did not look closely he could have installed the wrong rpm motor. There is another possibility, he may have used the wrong capacitor. I have seen the condensing fan actually operate backwards at a lower than normal rpm. The fan if properly installed will discharge air upwards.
Jul 17, 2012 | Goodman CLQ36AR49 Air Conditioner
NEED YDK-60B-6C MOTOR
This place has the YDK-60B-6C MOTOR in Stock and on Sale http://ptacsolutions.com/product.asp?itemid=162221
Jul 07, 2012 | Heating & Cooling
No aftermarket condenser/evaporator fan motors. Chinese.
We stock a complete line of parts for the Amcor Mini-Split Systems.
201-266-8234 option 2
Support@Pridiom.com
Oct 30, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
I have a noisy cooling fan. I have cleaned and removed all the dust from the vents in the compressor compartment, but the fan still make a squeeking sound. Can the fan be oiled or greased or should it...
Is the area between your fridge and freezer smoking hot? Can you smell the rubber seals melting? Does your fridge squeak like crazy? You have an issue with your condenser fan. You can save about $50 by fixing the fan motor yourself. I'm no engineer but this was an easy fix. 1) Unplug the fridge. 2) Take off the lower back panel covering the condenser and fan. 3) Unplug the fan (on the top left from the fan. 4) Slide the fan out of the bracket 5) Take the fan blade off. (This will take the most time and TLC, it is glued on) 6) Take the two screws out of the back of the housing. **The fan motor should be free of the housing and blade** 7) Remove the two screws from the fan motor housing. 8) Pull the shaft out of the motor and clean all parts with some oil and a rag. 9) Make sure all moving parts are well oiled then put the shaft back in the motor housing. 10) Replace the motor housing screws 11) Replace the motor into the fan housing and replace the screws. 12) Slide the fan blade back onto the shaft (I used some super glue to help hold it in place) 13) Slide the fan housing back into place 14) Plug the fan into the socket 15) Plug in the fridge to make sure your fix worked (it may take a minute to kick on) 16) Replace the lower cover
Aug 03, 2010 | Samsung RS2630SH Side by Side Refrigerator
Air circulator not working on unit
We stock a complete line of replacement parts for Amcoraire Mini Splt Systems.
Support@Pridiom.com
201-266-8234 option2
May 28, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Unable to find a panasonic replacement motor for dyson dc07 vac.
You can convert it to the YDK one if you get the YDK motor housing as well.
Mar 18, 2009 | Dyson DC07 All Floors Bagless Upright...
Blower fan runs at one speed - very low
There is a sensor on the indoor coil that needs to reach a certain temp before the fan speed will increase. Sounds like the unit is undercharged if the sensor isn't reaching the temp it needs to.
Mar 09, 2009 | AmcorAire UCHW-H24AF2 Split System Air...
AmcorAire  UCHW-H12AF2 Split System Air Conditioner Logo
2,902 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
