Question about Intel Desktop Board D850EMV2 Motherboard
Agp issues ok. I just built a pc out of an old d850emv2 motherboard. After putting all the parts together, I juiced it up and everything turned on fine...however there was no video signal. The light on the monitor went from blinking yellow to solid green, indicating it was recieving a signal, so i just reboot the pc. The next time it booted up, the monitor's blinking yellow light never changed and the motherboard made 1 long beep followed by 2 short beeps. Then Followed by 2 more short beeps. I've tried re-seating the agp and disconnecting all unnecessary parts to get it to work. The agp card is brand new, could it be faulty or could it be something else? pentium 4 2.4 ghz processor 1 gig rdram 250 gb hard drive ati radeon 7500
  • PimpDaddy77 Feb 14, 2008
    Another vid card solved the problem...but now I get a system halted boot error.
  • 178 Answers
Do you have another video card to try? If so try it. But it sound like something is not seated correctly. Please respond back. Also do you have a built on video card for this board?
Posted on Feb 13, 2008
I have a Dell Dimension 2400 desktop. It needs a monitor. I tried new ones from Best Buy and Office Max but they say no signal when I hook them up..I tried this computer with monitor in the following
Thank you for replying,
As per the diagnostic LED's, it is an issue with Video initialization failure. Your computer has onboard Graphics which is built into the Motherboard.
Video Initialization failure could happen if there is :
Unseated AGP card
Bad AGP card
Bad motherboard
As per your Svc Tag your system doesn't have AGP Graphics Card, Probable issue with MOBO.
This computer doesn't have a AGP Slot (Graphics Card Slot) to try connecting Graphics Card.
Need to repair/replace MOBO.
Thanks.
Feb 25, 2014 | Dell Dimension Computers & Internet
I have an old Compaq Presario 6420nx (6000) This happened after updating to a XFX 256 graphics AGP card, I installed all drivers and updated bios. After rebooting , no video,mouse or keyboard working. I...
If your computer works fine with an onboard video, it is possible that your motherboard is not getting much power. The agp video card gets power from the motherboard. I suggest using a different power supply.
Jun 01, 2011 | Computers & Internet
I bought Foxconn 755A01-6EKRS Motherboard for my HP pc replacement. i install my AGP VsionTek x1300 graphic card and turn it on and nothing show up on screen...then i put the graphic card back to my old HP...
Your new Foxconn motherboard Primary Graphics Adapter settings in set to onboard vga that is why there is no display in your monitor. Do not install yet your agp video card. Use first the onboard vga of the motherboard.
Power up your computer and go to the BIOS settings. Locate in bios about the Primary Graphics Adapter settings and then select AGP. Save changes and the exit. Turn off your computer and now install the agp video card.
Dec 16, 2009 | Foxconn 755A01-6EKRS Motherboard
Radeon 9550 + AGP issues on MSI KT4V
First of all, why do you bother to change all these spec? Secondly, since your screen flicked, I would suggest you just leave them like that. Your PC is just as old as mine, don't mess around with it too much.
Jun 13, 2009 | MSI KT4V (MS-6712) Motherboard
Black screen even the power is ok!!
Your Intel D850MV motherboard uses an AGP video card. There is no onboard video (built into the motherboard). Before replacing the video card try swapping out your monitor with another. Check for display. When the system is powered on can you hear the internals running? If the swapped out monitor does not show display you'll have to replace the AGP video card. The Intel D850MV motherboard only supports AGP cards that run at 1.5volts only & can run at 2x or 4x speed. Intel shows the difference between compatible 1.5v AGP card connector & the 3.3v non compatible video card connector. Click on the Intel link to see this; http://www.intel.com/support/motherboards/desktop/sb/cs-009010.htm This next link shows a compatible AGP video card that will replace your old card; http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4116644&csid=ITD&body=MAIN#detailspecs Thanks for using fixya
Jun 04, 2009 | Intel D850MV Motherboard
NO VIDEO FEED
just connect to your built in video card first , go to the bios next and disable the built in video card, F10 to save your settings , restart your PC. and connect to your geforece.
try it out.
Mar 24, 2009 | Foxconn 915PL7AE-8S Motherboard
Pc turns on when i plug it in but won t boot and won t turn off
Reset the CMOS to defaults. Since it is not actually booting properly you will have to jumper it. Hopefully you have the manual and you need to look at the layout and find what jumpers need to be shorted to reset
Nov 24, 2008 | Intel Desktop Board D850EMV2 Motherboard
Only boot in safe mode with Vista
Recheck that you have the exact driver for that ati card including the correct driver for the operating system you are using. physically pull the card and confirm the model of ati card you have.
also consider installing just the driver and not the catylist program.
Robert
Sep 01, 2008 | ATI RADEON 9600SE128MB AGP Video Card...
Intel Desktop Board D850EMV2 Motherboard Logo
98 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
