Question about Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher
Leaking Kenmore dishwasher
The plastic bottom of my dishwasher is cracked - causing a leak. Shouldn't the water be contained inside the tub and not go to the bottom of the machine? We are thinking of sealing the crack, but i'm afraid there's something else leaking in there. This washer is only 4 years old - I'm totally disgusted.
The plastic bottom is not removable/replaceable.
  • 54 Answers
If you are very careful you can reseal it with a soldering iron as it should be a sealed cabinet. i have seen one seald with a cheap sealr and the cabinet turned orange.
Posted on Feb 12, 2008
Why is water leaking from back of kenmore elite refrigerator?
Also, can be a crack on the plastic hose, close to the inlet water valve.
Aug 16, 2014 | Kenmore Refrigerators
Dishwasher leaking
When does it start to leak? I mean how much water goes in before the leak starts. I have a problem every once in awhile with mine leaking when the float in the bottom of the washer gets stuck and does not shut off the water. The way to check this is to locate the float, it is near the front left side, and push it up and down a few times to make sure it is not stuck. Try the washer again. If that is not the problem u could have a leak from the drain under the dishwasher. Sometimes the plastic can crack and cause a leak. Also check the discharge line and make sure it is not the problem.
Apr 20, 2014 | Whirlpool DU810SWPU 24" Full Console...
When washing dishes, the dishwasher starts leaking water through the base of the door.
The leaking could be caused by a couple of things. First check to see that the lower door edge and cabinet seals are intact and haven't been moved out of position, etc. (some DW's only have one seal, others have two) - can't be exact without model numbers, etc.)
Also check the water level switch, normally in the left front corner inside the wash tub. It is usually under a cover that is either held in place by a plastic clip or a small 1/4" screw holding it to the tub bottom.
Remove the cover and clean the float underneath, it's possible that it's gotten gunked up over the years and is sticking or has a buildup inside it that is causing it to not float properly, hence it'll allow for overfilling of the wash tub.
Put it back together and run a short rinse cycle to see if that has resolved the leaking. If not, it could be the float switch has moved out of position, but that is not a typical problem unless the DW has been removed recently and got damaged, etc.
Hope this helps resolve your problem! Best Regards!
Jul 31, 2009 | Kenmore Dishwashers
LEAKING FROM BOTTOM
Is it leaking only when it is filling or all the time? If it is only leaking during fill, it could be an air gap device
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • If it is leaking all the time it could be the main tub seal. Hope this helped.
    Jul 16, 2009 | Roper RAS6233KQ Top Load Washer
    My ge dishwasher will drain but after a few hours
    Could be a crack in the tub, bad seal at the pump if water is leaking out onto the floor. If water is pooling inside the DW then a bad water control valve allowing water to leak back into the tub from the source.
    Jul 07, 2009 | Dishwashers
    My Kenmore under counter ultra wash dishwasher model 665.15825691 has started leaking at the lower corners of the door. The leaks seem to occur during the final rinse while the water is being heated. I...
    Happened on my dish washer too. Remove lower rack, remove lower spray arm by removing the center plastic nut, check screws (torx) on outside edge of pump. Tighten these as necessary, mine were loose causing water to spray forward against the tub causing leakage.
    Jun 27, 2009 | Kenmore Dishwashers
    Dishwasher tub leaks underneath
    Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
    Jan 17, 2009 | Kenmore 15899 Built-in Dishwasher
    Dishwasher leaks water
    hi there,
    dishwasher leaking might be due to either of these causes, check these:
    Main tub seal
    Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
    of the dishwasher, the following instructions probably apply to you.
    But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
    entire pump and motor assembly.
    The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
    leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
    remove the:
    * Lower rack
    *Spray arm
    * Spray arm support
    * Wash/drain impellers
    Then try the seal out of its housing and replace it.
    Door gasket or seal
    Over time, door gaskets and seals harden and lose their ability to seal properly.
    You can't repair the seals. You need to replace them if they've begun to leak.
    Water-inlet valve
    The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
    rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
    or repair/replace these as necessary.
    The water-inlet valve could mechanically stick open. When that happens, the water continues
    to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
    dishwasher, and replace the valve.
    Hoses
    Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
    leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
    Nov 03, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
    Dishwasher Leaking
    hi there,
    Main tub seal
    remove the:
    * Lower rack
    *Spray arm
    * Spray arm support
    Door gasket or seal
    Water-inlet valve
    Hoses
    Aug 27, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
    Leaking water on floor in front of dishwasher
    If your dishwasher leaks, check these:Main tub seal
    Door gasket or seal
    Water-inlet valve
    Hoses
    Main tub seal
    Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
    The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
    1. Lower rack
    2. Spray arm
    3. Spray arm support
    4. Wash/drain impellers
    Then pry the seal out of its housing and replace it.
    Door gasket or seal
    Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
    Water-inlet valve
    The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
    The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
    Hoses
    Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
    thanks for using FixYa
    Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
    Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher Logo
    138 people viewed this question
    Top Bosch Dishwashers Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
