Question about Dryers
Kenmore series 90 dryer
I have a series 90 dryer, that I have taken the lower front off to gain access to the dryer motor. I then took the plate off that is in front of the dryer motor. I was hoping that the drive belt was broken, but I can reach behind the motor and tug on the belt. The belt is still attatched,but I can't see if it is in a bind. There is a humming noise when the dryer switch is turned on and the dryer drum will only move a fraction, I then turn the dryer off b/c I am afraid of burning the motor up.
Any Suggestions??
  • jeffcoat83 Nov 30, 2008
    but i know the belt is broken, its just the dryer dosent do anything
Dryer wont start i hold the button in and timmer tiks but wont start
Posted on Apr 11, 2008
  • 240 Answers
I hae to say it, but it sounds like the motor has already gone out. That loud humming noise is usually the start windings going out. There is no other way easily to tell if the motor is out, but taking the belt off and saying it doesnt look broke what work in this situation. I would imagine that you have a DOTT (Dryer Of Tommorrow, Today) dryer, because you said it had the front panel. The motor part number is 279787 if this the case. Good Luck, and let me know if you find out any new information or need further help.
Posted on Feb 13, 2008
Where is the toe plate of a kenmore dryer model 90 series
You should be able to see it is right on the front it divides the dryer in two right below the door.
Jan 15, 2016 | Kenmore Dryers
How do I remove front panel of kenmore 90 series dryer to check for lint build up
Unplug your dryer first, of course. For the lower front access panel there are two screws near the very bottom of the panel. Take off the duct assembly by removing those two screws and a third one at the very bottom of the duct assembly where the bracket is attached. That should do it! Hope this helps!
Jul 16, 2011 | Dryers
I have a Kenmore 70 Series Washer. The lid switch
Bob your an the right track.. remove the two screws ( unplug washer ) pull sw from mount and the wires will folow. they are hooked to a wire clip . with it in hand you can see if sw is cracked or broken .. the new sw will come wire& plug/ you can splice it or remove wire harness and reinstall as you took it appart . the 70 series has a lift up top / two clip in front / use a putty knife . ..mm
Dec 04, 2009 | Kenmore Elite HE4 Electric Dryer
My Kenmore Series 90 dryer won't run as it appears the door does not hit the actuator. It would appear either the door has moved to a lower position or the actuator has moved up into the dryer. May I ask...
The door switch or actuator is broken. A common problem. On most Kenmore dryers this is replace by lifting the top. Since you haven't given the whole model number I will discuss raising the top on the most common model.
If your model has a lint filter at the top the slide show below should show you how to raise the top.
Kenmore Dryer
Disconnect power to unit. Lift the cover from the lint filter or if yours is the one with a filter and cover together, remove the whole filter. You will see 2 screws under the cover/filter, remove them. Now, you will need a putty knife or a thin shafted straight screw driver to remove the top panel. Push the putty knife or screw driver to "pop" the front top clips. The top panel will hinge back towards the wall and can be left there. Just inside the top of the front panel, you will see 2 screws, remove them. You will see the wires for the door switch on the right side. *** the top of the front panel toward you to gain access to the switch for replacement.
Reverse process for reassembly. Good Luck
Sep 19, 2009 | Kenmore Dryers
We have a Kenmore dryer series 90 model #11066904690 that we started spelling a burny smell. We took off front panel and vacumed out we tryed to use it again and same thing happed and then shut off...
This could be a couple of things. But more than likely the motor has burned out. It could be a wire has burned off, or even the timer has burned. Since you say it "shut off completely", I would have the power cord checked where it connects inside the dryer. UNPLUG it from the wall first! I have seen one wire burn off there from being a loose connection. There is a cover plate you can take off and look inside.
Jul 29, 2009 | Kenmore 659 Electric Dryer
Electric kenmore 90 series working but no heat?
Most likely that is the heat element. Some dryers have the element in the front but most of the time yours can be accessed from the rear.
May 10, 2009 | Dryers
Kenmore dryer- remove fan to change motor on dryer.Do I need a gear puller to remove ? 7 yr old 90 series dryer ,seal drum came lose from damage to dryer when purchased. Did not relize damage until motor...
The wheel has left handed threads. Use an impact wrench and an adjustable wrench to get it off or get a vice grips or pipe wrncha nd lock down the shaft then get a stick of wood or a hammer handle and shove it in between two fins at the 3 oclock position. Slam downwards on the wheel and it should pop loose.
Mar 22, 2009 | Kenmore 659 Electric Dryer
Kenmore 90 Plus Series, no power!
yes there a fuse in the front dryer it is white thermo fuse ck it
Feb 28, 2008 | Kenmore 63942 Dryer
Broken Kenmore dryer 80 series
Hi Dave. The problem is the drive belt. They aren't that difficult to replace and can be done with just a few tools. I'll need the exact model number off of the dryer to explain how to gain access to it, though. The number can be found behind the door on the cabinet (it'll start with 3 digits then a decimal point then more digits, like this; xxx.xxxxxxx)
The part number for the repair is 4392065. This is a complete maintenance kit for your dryer. I recommend it because since your belt wore out, there are other parts that should be taken care of at the same time. Here's a picture and a place to order if you can't find it locally.
Oct 18, 2007 | Dryers
Dryers Logo
579 people viewed this question
Top Dryers Experts
