Question about Sony PlayStation 2 (PS2) Console
Disc Read Error
Ok, I've been having disk read errors on my 30001 Playstation 2, I cleaned the lens and that worked perfectly, it read silver and blue sided discs, shortly after it stopped reading silver sided discs, I tried adjusting the voltage, I don't think that worked, and I've tried moving the white cog inside the ps2 but that resets back to what it was everytime I turn the machine on, is there a way to make it stop resetting itslef?
  • pacit Feb 13, 2008
    Dang it, I was hoping you didn't say that, haha, oh well, I don't know, I might try to look for a replacement on either the lens or a used system. It's not a big deal, I was only trying to play it for a custom Guitar Hero 2, ha but alright then, thank you
  • 47 Answers
There is not a way to keep it from resetting, however it does sound like the lens is bad. Since it sounds like you have no problem working with them you can get a new lens cheaper than buying a new machine. The 30001's had 2 or 3 different type lens in them. You can seach ebay for them, they are normally for sale there around $40-50 last time I checked. Since cleaning and adjusting does not fix it, I think this is the last resort, other than full replacement of the system :-) Sorry....
Posted on Feb 13, 2008
Disk read error
The reason your play station 2 keeps reading disc error is either because the lens is weak, dirty, or the disk is not compatible with the console.
You can try to use a lens cleaner to clean the lens or totally replace the lens with a new one.
You can also try other disc to see if its the same thing it will show.
Take care
Oct 09, 2010 | Sony PlayStation 2 (PS2) Console
The gamr big ol bass 2 does not work on my ps2
If you're getting a Disc Read Error, you may need to clean the disc. Inspect it for scratches. Is it the only PSX game that won't work? If all your PSX games won't read, you should clean the lens of your PS2, although the read errors are a sign of lens damage.
Nov 07, 2009 | Konami Big Ol Bass 2 for PlayStation 1
Playstation 2 Disk read error.
try cleaning the disk with cleaner if you dont have cleaner use water
Jan 21, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 Disk read error
Its almost always the laser. I would bet on the laser.
Will play CD's but not DVD's or Games
You have to take the box apart and clean the lens.Ok !
  1. The white plastic gear that moves the laser must make contact with the "motor". A bad contact here can cause disk read errors. Sometimes it looks Ok, but you may need to remove the lens and bend the white gear for good contact.
  2. The two rails on which the lens move must be very slippery - which can be lubricated with cooking or motor oil. Usually the holes where the rail is (on the right side of the lens) are dirty or you have to bore then out slightly, making the holes bigger.
  3. The lens uses little torx screw (black) that move the lens up and down on the rail. Usually the lens is too high and requires adjustment.
  4. Take the lens off these 2 rails and take the black plastic cover off. Turn the lense upside-down and you'll find there are 2 screws (silver, phillips or torx) that you have to remove to take the upper little lens off.
  5. Then you'll see a larger lens that is usually very dirty (this lens is a mirror to light). If that's dirty, it will give a disk read error. You'll have to take the little electric board off that you see on the other side of the big lens-mirror. It's probably dirty too, so clean it. Alcohol should work OK for this task.
  6. The lens bottom has 2 + 2 screws. You move the upper "little" lens up-down-left-right (this may require a special screwdriver)
  7. The motor "rail" that moves the lens must be very clean and oiled and the 2 rails too.
Jun 06, 2008 | Sony PlayStation 2 (PS2) Console
Unable to load playstation dics or any other discs for that matter
Jun 05, 2008 | Sony PlayStation 2 (PS2) Console
Silver bottom games
You may want to replace the laser
Mar 26, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error
I had that same problem, Just purchase a cd lens cleaner and it worked.
Dec 10, 2007 | Sony PlayStation 2 (PS2) Compact System...
Disc reading
Replace the lens with a new one.
Sep 01, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
63 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
