Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver Logo
Anonymous Posted on Jan 20, 2010
DROPPED MY BLACKBERRY 8130 BLACK SCREEN WHAT TO DO
Anonymous
Level 2:
New Friend:
  • Expert 85 Answers
  • Posted on Feb 25, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
85
Questions
0
Helped
27187
Points
213
Odly enough and i know it sounds crazy try dropping it a few times from a safe similar difference....
It worked for me I could not beleive it when I read this on blackberry forums.com but it worked just please be careful.
Trying to activate a unlocked Blackberry Pearl 8130 for cellular south carier
you Need to Unlock your Blackberry Pearl 8130 for south carrier or any network.
you can unlock your Blackberry bysimple entering unlock code through key pad, after unlock your Blackberry youcan use it with any GSM SIM card around the world. I know this trust fully Blackberryunlock code provider. I hope this Blackberry unlock code will very help fullfor you
How do I remove the sd card from the 8130 blackberry pearl?
As you look at the phone, in the left side is a door with a simbol on it like a SIM card. Open with carefull that door and you`ll see a black line about 3 mm thick. Press on it and you`ll hear a click then remove your finger and the card should pop out.
My blackberry 8130 keeps going to a white screen
Sounds like you need a new LCD screen. Somebody needs to open your Blackberry and replace it. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is an Blackberry 8300 Repair Guide that shows how to repair a Blackberry.
Help on home screen
your menu button you should have a "show apps."
I dropped my phone in a toilet a few months ago, andi dried it immediately, and it worked fine the same day. but a few days later, the screen started to flicker black, and now the screen doesnt appear at...
The screen does not appears when it is caused with water damage problem.
I would like to suggest you to service the handset or it might cause other damages also.
Thank you for using ' Fixya ' and have a nice day!!
1helpful
Blackberry pearl 8130. screen wont come on.
To help you with this problem, I want you to know that when a cellphone got fell, the main problem will be make is lost in display,you will not see anything but you can hear something like message tone and start-up tone, you can also receive calls. Don't be worry with that kind of problem. To tell you whats happening inside your phone is your LCD of display connection is only misaligned. Get it to the nearest cellphone repair center to get your cellphone to be open by a technician and probably they will do dismantling your phone and fix the problem. Hope this could help. Don't forget to say thanks..:-)
1helpful
2answers
Dropped blackberry 8130 phone will vibrate if called but no screen and buttons are not working
Hi
probably you have 1 broken keypad ic on your 8130 or some broken soldering because of impact. best advise i would be able to give you is for you to find a proper blackberry repair centre like www.E-Repairs.co.uk and get your unit check
Thanks
Phone won't turn on
loopiy doopiy! haha you thought this was real! sucks for you
I have a verizon rim Blackberry Pearl 8130, i need keypad
Go to Ebay.com and do a search for Blackberry 8130 Keypad.
You should find what you need at a reasonable price.
Top Verizon Communications Cell Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
