Question about NorStar M5316 Centrex Corded Phone
"NO CALL TO PARK"
My phone seems to be frozen, any button I press it display's "No call to park" on the display, It's blasting music and I can't even turn down the music.. I have tried unplugging and replugging the phone in and it doesn't do anything... Please help! Please reply to my office email:
stephanie.gouveia@wwcb.ca
  • ajgentryuk Dec 08, 2008
    Every button pressed produces and error bleep and this display message.
It sounds to me like the park button is stuck. Try pressing it a few times to see if it will come unstuck. If that doesn't work try unprogramming the function for that button. (see manual)
Posted on Feb 19, 2008
Numark ndx400
1 of yor tak switchs are faulty either cue or play button or maybe even the scratch button replace all 3 that should solve
Aug 03, 2013 | Music
Buick automatic transmission linkage
Easy fix, it's your transmission linkeage bushings. They do break because they're plastic. Dorman makes them.
Nov 08, 2017 | 2006 Buick Rainier
When a call is parked, we only have a minute to divert the call otherwise it then rings all the phones is there a way of delaying the set time period?
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the pool on.
Press the next key 6 times (bottom right arrow) .
The display should saySystem Prgrming.
Press the show key (top right arrow)
The display should say Hunt groups
Press the next key 2 times (bottom right arrow) .
The display should say Featr Settings.
The display should say backgrnd Music
Press the next key 4 times (bottom right arrow) .
The display should say Park Timeout:60
Press the Chng soft key till you change the park timer to the desired time length.
Press the release key when finished
Oct 01, 2009 | NorStar T7316E Corded Phone
Shifter stuck in park.
The BTSI (Brake Transmission Shift Interlock) has a small spring retainer on the park safety. A small plastic tab breaks & releases the spring. This requires the shifter to be disassembled in order to be repaired.
Repaired mine Sunday May 1st and can provide detailed instructions if desired.
If you are lucky, your brake interlock is the only problem. There is a bypass switch located beside the gear selector. Remove the small "cubby" bin located next to the gear shift by simply lifting up to remove. You will note a small access port and a pink button contained therein. Press the pink button to override the brake interlock.
If you still cannot shift into park, then the shifter must be removed for the spring repair. Even if yours is still under warranty, you will get another shifter that will eventually fail due to poor engineering.
Please let me know if you would like my assistance.
Aug 20, 2009 | 2006 Dodge Magnum
I have a 1993 park ave and need to now how to reset the transmiss
if you got climate control air conditioner control buttons turn on ignition key enter the self diagnostic system. select pcm override ps13 tps sensor learn.press the warmer button. the driver information center should display 09.indicating that the garage shift value has been reset.select pcm override ps14 tran adapt.press the cooler button the dic should display90 indicating the up shift adapt value been reset.press warmer button the dic should display 09 indicating the steady state adapt value has been reset. press and hold the off and rear defog buttons on dic until the message .transaxle oil life reset is displayed on the dic.
Apr 11, 2009 | 1993 Buick Park Avenue
My Transfer and Park buttons are not working - on my M7324 phone. They used to.
You need to reprogram the features to buttons. Try this:
Press "Feature*3", then press the button to be programmed, and enter the associated feature code (below).
Transfer - Feature 70
Call Park - Feature 74
Good Luck!
Apr 03, 2009 | Nortel Meridian 9417CW 2 Line phone
1995 Cadillac SlS Shift lever knob will not move, seems frozen.
Put your parking brake on. Remove console panel. Put foot on brake. Turn ignition key to on position (Do NOT start vehicle!). Locate park lock cable (Parallel to drivers right knee). Press down on that cable with left hand while attempting to move shifter with right hand. Replace that cable if shifter moves out of park.
Feb 23, 2009 | 1995 Cadillac Seville
Call Park Issues..
Well to place a call on Park:
-> you should answer the call -or- be on a call
-> press FEATURE 7 4
-> then look at the display as it will give you a park number
Anyone can pick up a phone now, then dial that park number which you've seen - to answer the call.
To Transfer:
-> press FEATURE 7 0
-> then dial the extension you want to transfer to...
Now you can either stay on the line to tell the person who you are transferring and then hang up the phone -or- just hang up after dialling the extension to complete the transfer.
Jan 26, 2009 | NorStar M7310 Corded Phone
Norstar 7310 won't park calls
Are you using the feature code to park the calls or a PARK button? If you are using a button, check its real designation by pressing FTR *0, then press the button marked PARK. The display will show you what it is programmed as. To reprogram it, press FTR *3, press the PARK button, then press FTR 74. That button will then be PARK. You should always be able to do it manually by pressing FTR 74 while on a call to park it.
Aug 09, 2007 | NorStar M7310 Corded Phone
NorStar M5316 Centrex Corded Phone Logo
141 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
