Question about JVC GR-D270 Mini DV Digital Camcorder
Wont power up after the AC power was plugged in with it in play mode
Did this fry something? Is there a reset or fuse that can be replaced?
  • Voodoo Chile Feb 13, 2008
    How do you get to the fuses
    President:
  • 4,402 Answers
There are fuses inside it possible, make sure you snap the battery in firm.
Posted on Feb 12, 2008
  • Cary Farah
    Cary Farah Feb 13, 2008
    you will need to take it in for service there not just a snap in type fuse there are wired to the board and look like resisters.
    please mark the post as fixya!
My Microsoft Xbox 360 Pro's power brick wont turn
You can try to Reset the AC adapter by following steps below.
1. Unplug the xbox 360 AC adapter at both ends (from the back of the system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
If this doesn't work it's probably fried from the power surge.
Jul 31, 2012 | Microsoft Xbox 360 Console
Can't turn on/off using either switch on front or remote. was plugged into outlet on cable set-top box. perhaps something was fried by sudden power outage.
In that case if ther is no power you better check first the power in the outlet they have.Then check the continuity of AC cord of the TV.If they are good,check the fuse,located inside at the power supply section near the AC supply voltage input.Replace same value of fuse if busted.Then try to turn on again..Try this procedure,hope will it help you..Thanks..
Aug 26, 2011 | Toshiba MD20FN3 20 in. TV/DVD Combo
I know that the Wii console has a smart fuse and that you can reset the the console i had to do this one time before when the power went out and the machine was still under waranity but is no longer and I...
Plug out the AC Adapter / Power Cord for 2 minutes.
That should reset it.
Plug it back in and try to turn the Wii on.
If that does not reset it, the AC Adapter may be fried.
You can find a new one at the following website:
http://store.richspsxparts.com/ofniwiiacadr.html
Apr 19, 2011 | Nintendo Wii Console
MY RCA D52W20 52" WONT TURN ON!!!!!
Check the fuse on the AC filter board. If you trace the power cord into where it plugs in on the small skinny board located on the right side when looking in the rear there is a fuse on that board. If its completely dead I would suspect that fuse.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Duo Therm Penguin model 610115.311 AC unit no-power
Actually you should have fried you converter. What is the voltage reading you get for the air conitioner? supply? One should run off the generator and the other on shore powerIs it set up that way?.
Sep 28, 2009 | Heating & Cooling
When lighting hit and the wii go out what do i do to make it come on
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
Try the following steps in this order:
FIRST:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
SECOND:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
THIRD:
- it might be cheaper to replace the AC adapter with another one
FOURTH:
- get the unit repaired
MUST DO:
- buy a good SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Hope that helps!
Aug 01, 2009 | Nintendo Wii Console
What will happen if it is plugged into a 220 volt AC
Hi there, it depends where you got your Wii from.
if your Wii was from japan or another country which uses only a 110v AC power supply then you could have either blown some fuses inside the wii or at worse you could have fried some of the internals.
First of all find out which adapter you where supplied with, check the voltage rating on the adaptor. if it is a 110v adaptor then you may need to have your Wii replaced.
Hope this helps
Oct 28, 2008 | Nintendo Wii Console
[[ACER WONT TURN ON]]
You might of fried the whole motherboard when it sparked. Check if there is a fuse. Bridge the gap, and it should turn on. If not PULL THE PLUG.its something else that went wrong.If you don't, it smells really bad. Ive learn't from experience...
Jul 28, 2008 | Acer TravelMate 2300 Notebook
JVC GR-D270 Mini DV Digital Camcorder Logo
74 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
