Question about Brother MFC 5100c InkJet Printer
Brother MFC 5100C making white line in printing
My Brother MFC 5100C is making white lines when I print. I've changed the ink cartridges a few times, but still same result. Do I need to call a service technicien to clean?
The printhead is probably clogged. You may be able to clean it, by removing the mechanism and soaking the actaul printhead in a solution of white vinegard or you may have to replace the printhead. A web search may result in instructions on how to remove the head. Prinheads appear to still be available via Ebay and others. They run about $60-70 and if you have a bit of tech abilities, replacment should be relatively easy to do yourself. Not sure about finding a repair center that will do it for you or what the associated cost would be..
Posted on Apr 30, 2008
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7440 - white line running vertically through printed page.
If its a laser printer you might have a line on the drum. Lift the flap on the toner cartridge and spin it to see if you have anything on it. Also the drum. When you find the line take a soft brush or lint free glove and lightly remove it Your problem should be solved. If a inkjet printer you need to clean print heads. To do this go to your printer model in control panel and right click you will see in the list the utility. Some times in properties. Choose to clean heads You might have to do it a few times.
May 27, 2012 | Brother MFC-7440N Laser Printer
My Brother HL1230 printer prints with whole lines of text missing several times on a page and gets worse by missing more lines if printing several pages. It has a new toner cartridge. How can I sort this...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 28, 2010 | Brother HL 1230 Laser Printer
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother 420CN printer will not print black ink. Have replaced the cartridge and after several cleaning cycles, it still will not print properly. Test Print shows colors are fine but black ink is hit and...
Good Luck
RK
Dec 20, 2009 | Brother MFC 420CN All-In-One InkJet...
BROTHER MFC-210 PRINTING IN BLACK INK POOR QUALITY BUT COLOURED INK FINE. USING INK MANAGEMENT TO CLEAN PRINTER NOT HELPING. HAVE TAKEN OUT AND REINSTALLED BLACK CARTRIDGE WITHOUT IMPROVEMENT. WHEN...
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Dec 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
Black ink in brother 240c printer does not print new cartridge
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
MFC-5100C won't print all colors...
Hello 4wards,
Try getting one of the expensive cartridges, some printers don't use all of the cheap inks, because it prints out only the acceptable colors. Get a better Ink Cartridge and it should be fine.
Hope this Helped - NeWeVoLuTioN
Sep 04, 2008 | Brother MFC 5100c InkJet Printer
Brother MFC 5100c InkJet Printer Logo
243 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
