Question about Linksys Wireless-G Broadband Router
Wireless Repeater I have two WRT54G, can I use one as a Repeater?
  • 55 Answers
There is no option in the router to act as a client. You could set it up as a second access point and connect them via Ethernet, or I believe there is a Linux distribution you can load on the WRT54G that can act in repeater mode, but I've never installed it, so you would have to research that yourself.
Posted on Feb 13, 2008
2 Suggested Answers
SOURCE: Setting up a WAP54G as a wireless repeater with a WRT54G
wap54g as wireless repeater doesnot communicate
with wrt54gx
Posted on Dec 19, 2008
Download software
http://support.linksys.com/en-us/support/routers/WRT54G
Oct 24, 2013 | Linksys Wrt54g-tm Wifi Wireless Router,...
I am trying to set up a WiFi N Repeater but having no joy. I have followed the set up instructions and it states that the repeater is being updated then when complete there is nothing!! At lest I get an...
it sounds like your having an issue with the repeater not actually joining your main network correctly. do you know if your repeater is set up in bridge mode? also do you know what IP address you are getting when connecting?
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_2ebcd3cbc4810dbf
Oct 06, 2013 | Linksys Wrt54g V1.1 Dd-wrt Tomato Wireless...
Repeater isn't getting signal
Plug the first router into a LAN port on the router you are using as a repeater. Don't plug into the WAN port. That should make it work
Jun 17, 2012 | Linksys Wireless-G WRT54G Router
WRE54G To Connect With The WRT54G in repeater mode
hi..you only need to reset your router..their is a small hole at the back and just push a little pin to make a resets...Thanks..Good Luck..^_^
Mar 27, 2009 | Linksys Wireless-G WRT54G Router
WRK54G as a repeter
Okay, if it is a wireless repeater, you simply cannot, the WRK does not have such capabilities, but WIRED, that may work.
By default the routers IP is 192.168.1.1, so turn off the DHCP of the WRK, then change the IP to 192.168.1.something else. for the cable routings, from the primary router's ethernet cable should be plugged in to any LAN port of the 2nd router.
then you can relocate the 2nd router to where it has to be as long as the cable reaches it (not longer than 200 feet)
for the wireless settings, just make a different wireless networks for both routers.
if you have other questions just lemme know
Nov 02, 2008 | Linksys Wireless-G WRT54G Router
Connect wag200g to wap54g wireless
Hi!
I am sorry to say this but the accesspoint WAP54G's capability as a wireless repeater can only be used with a WRT54G, WRT54GS and another WAP54G.
That means it will not work as a wireless repeater for the WAG200G gateway. If you need a wireless repeater, you can use a WRE54G. This is a Linksys wireless repeater and is compatible for all wireless AP's.
If you have any other questions, you can ask me and I'll help you.
Sep 18, 2008 | Linksys WAG200G Router
WAP54G's as repeaters
Are you trying to setup both access point to repeat the signal of the router?
The correct way to setup the AP's as repeater is to access the setup page of your router go to status and go to the wireless subtab, check what is the MAC address that is what your suppose to configure on the AP's not the LAN MAC address which is on the local networks subtab on status.
Access the setup page of the AP's and go to AP Mode, make sure that you choose the repeater and copy down the Wireless MAC address you obtained from the wireless router. To enable roaming, meaning your wireless computer/device will connect to the AP/router closest to its location, change the wireless channel on all three device for example WRT54G will be on channel 1, 1st AP as repeater on Channel 6 and the last AP to Channel 11 but the other settings must be the same(Wireless name(SSID) and Wireless Security).
Note: Setting up an AP as repeater to repeat or extend the signal of another AP that is set to repeater is not recommended since the signal will deteriorate due to the number of hops the packets will be sent.
Hope this will help you setting up those WAP's which for me is quite useful since you can set it up to act as a repeater, AP client and a bridge to a WRT54G router.
Regards,
Sep 10, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRK54G versus WRT54G Firmware
Hi...
The WRK54G is actually a stripped down version of the WRT54G that was bundled with a wireless network adapter and sold under the kit name WKPC54G.
From what you say in your question I gather that you have a WRT54G already in place as your access point, and it is what is connected to your WAN. To use the WRK54G as a range extender repeater you should do the following:
1. Turn off DHCP
2. Turn off NAT
3. Assign a fixed IP that is in your Class C Block
4. Define the WRT54G as the Gateway
With this configuration it now should function as an extender/repeater, and any clients connecting to it will be serviced by the DHCP on the master router.
I hope that this helps.
Nov 15, 2007 | Computers & Internet
Requirements for WAP54G & WRT54G Repeater Mode function: * WRT54G: Firmware 2.02.2 or higher * WAP54G: Firmware 2.06 or higher Go to http://www.linksys.com/download to download the latest firmware upgrades for both devices. . Accessing the Router?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the Router into the Address Bar (192.168.1.1 is the default IP Address). 2. Click GO or press the [Enter] key. The User Name and Password prompt will appear. 1. Leave the User Name field blank. 2. Type admin in for the Password (the default Password). 3. Click OK or press the Enter key. The Router?s Setup page will open: * Click on the Status Tab. * Click on the Wireless sub tab. Write down the Wireless MAC Address and the Channel number values located on this page. If the Encryption Function is Disabled, go to the WAP54G Repeater Setup section below. If Encryption Function is Enabled: Note: WPA (Wi-Fi Protected Access) is not yet compatible with wireless repeater mode. You must use WEP Encryption if you wish to use security options with this configuration. To gather WEP encryption information, click on the upper Wireless tab, then the Wireless Security sub tab. Write down the Passphrase. WAP54G Repeater Setup Be sure that you have the WAP54G plugged directly into one of the WRT54G?s numbered ports for the duration of the setup. Accessing the WAP54G?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the WAP54G into the Address Bar (192.168.1.245 is the default IP address). 2. Click GO or press the Enter key. 3. The User Name and Password prompt will appear. 4. Leave the User Name blank. 5. Type in admin for the Password (the default password). 6. Click OK or press the [Enter] key. The WAP54G?s Setup page will open. 1. Set the Channel value to the same channel as the WRT54G router that was obtained from earlier steps. 2. If WEP encryption was enabled on the WRT54G: * Select Enable for the Wireless Security option. * Click on the Edit Security Settings button and enter the same Passphrase as the one of the WRT54G router that you recorded. Click Generate to populate the WEP key fields. * Click Save Settings to save your changes and close the encryption window. Click Save Settings to save your changes on the Setup page. 3. Next, click on the AP Mode tab. * Select the Wireless Repeater option. * Enter the WIRELESS Mac Address from the WRT54G that you recorded. (Disregard the fact that the page asks to ?Enter the LAN MAC ADDRESS?). Click Save Settings to save your changes. Close your web browser. You can now place the WAP54G Access Point in another nearby location (with its power adapter plugged in) so that it can repeat the wireless signal that it receives from the WRT54G. Notes: * The ?SSID? of the WAP54G does not have to be the same as the WRT54G. This can be used for initial configuration; using a different SSID will enable testing of network connectivity, and will show that the WRT54G is associated with the WAP54G. * If MAC Filtering is configured on the WRT54G, no extra configuration is needed. Wireless clients will still need to be added the MAC Filter list of the WRT54G, but the WAP54G does not have to on the list.
Feb 16, 2006 | Linksys (WRT54GC) Router
Linksys Wireless-G Broadband Router Logo
102 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
