WASHER CODE I HAVE A KENMORE ELITE CALYSPO WASHER. IT IS FLASHING L5 CODE AND WON'T WORK. WHAT DO I DO TO FIX IT. THANK YOU
  • Anonymous Feb 17, 2008
    I unpluged my unit to try and reset and still get the LS code. Has anyone tried replacing the switch on their own ?
  • brightwell Jul 02, 2008
    L5 code appears on my Kenmore Elite Calypso main washer wondow, It will not start. Sometimes if you pushdown near the front right nearest conner the minute LED will come on and start
  • 552 Answers
You have a lid switch problem.
check for junk plugging up the area of the lid switch.
It needs to move both to the contact position(when door is closed)and to the non contact position(when door is open).
Also, the switch may be bad, or the wires going to it may have been cut by the drum because sometimes these wires are not fastened good enough and are able to contact the drum.
Anyway, the switch is just like turning a wall light switch on and off.
There may be an actuator on the door that presses against the switch, that could be missing(fallen off/broken off).
Posted on Feb 12, 2008
    Problem Solver:
  • 17 Answers
What you are getting is actually a LS code...but it looks like L5.
LS Lid Switch Error The control will flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the status of the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display.
Usual first step with anything electronic is unplug, leave 30 minutes and plug back in - this will generally reset the "brain".
This will be a first step...hopefully it works...
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Kenmore elite 45986 front load washer the F02 code is flashing, how am going to remove this code, what is the problem please help me solve the problem thank you al
you have a clogged pump, you will have to remove lower panel, and clean pump. you will need torx screw driver, or call a service company
Please rate/vote this response, thanks
Dec 20, 2010 | Kenmore Elite 45986 Front Load Washer
How do i fix my kemore elite calyspo.with code ca flashing
how are u am scott hope i can help ok i have the same washer this CA code means AVERAGE CURRENT LIMIT, OR INSTANTANEOUS CURRENT LIMIT. if a status comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either "CA" for average current limit trip, or "CI" for instantaneous current limit trip. AVERAGE CURRENT TRIP occurs if there is a 2-second average of current draw greater than 5.55 amps at the motor windings. INSTANTANEOUS CURRENT TRIP occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. or overloading the unit may cause this problem. press stop/cancel to clear the display good luck
Feb 17, 2010 | Kenmore Washing Machines
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore calyspo washing machine flashes code CE
The problem is a communication error between the control panel and the control board and the motor control. You can try unplugging the washer for about 5 minutes to reset it but if that doesn't work you will need to replace one of those parts. Without hooking up a volt meter however to determine which one is causing the problem I couldn't tell you which one. You may need a tech to come out and see what one of those three is the problem. Try unplugging it first though and see how that works. Let me know if you have any other questions and if this was helpful to you. Good luck and I am glad I could help you.
Jan 18, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite quiet pak 4
its a inlet water supply error code check your cold fill line and fill screens at cold fill valve for block
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
For the kenmore elite oasis he top load washer, what does the error code DL mean and how do i fix it
We jamed a straw in the door lock so the sensor thinks there is something in there
Jul 02, 2008 | Washing Machines
Kenmore elite calyspo washing machine model #110.2206
that washer the noise you are saying i have found maney things the most common one being the break and basket drive
Feb 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite HE4T washer
Get the same code 2 minutes into cicle. F H
Nov 03, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3t
I am getting an F35 code on the washer has anyone had this problem
Sep 21, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
393 people viewed this question
Top Washing Machines Experts
