Thank you for your earlier reply. You asked for some more information. My washer is a Bocsh E-Nr.wf02467GB/15 serial FD 8511615268, and it is a front loader. Is there anymore help you can give me. Thank you.
There are concrete or other material weights at the bottom of the machine. One of them could be cracked and moving around.
The bearings could be going. If this is the case, then take off the back cover of the machine and try moving the drum up and down with nothing in it.
If there is movement, you have loose bearings.
You may also have a problem with the drums suspension system.
The only way to know is to look inside.
I will try to get the bach off and have a look. Thanks for now.
