Fellowes Manufacturing Powershred  DM15C Shredder
Novitech shredder
shared by 7 users
posted by snowbut on Feb 12, 2008
Certain cross cutting teeth jam and the paper will stop on that side and then jams as the rest feed through
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Posted by hfeldman340 on Dec 02, 2008
I have a Novi Tech paper shredder Model PD 026/B2
It only works in reverse and will not shred.Is there a way of opening it so that I can clean out anything that might be stuck in it
Thanks,
hfeldman340@aol.com
Posted by tshaw1977 on Oct 22, 2008
my shredder will not completely shred papers it starts to shred then stops
Posted by dmdwmummert on Aug 28, 2008
Need the plastic gears for a NoviTech PS-026/B2
Posted by ogginatsog on Aug 17, 2008
Novitech (Model No. PS-026/B2) Plastic gears stripped right off. I had this piece of junk 6 months and used it lightly.
Posted by anitaanders on Jul 03, 2008
I cleared a paper jam but now the unit won't run
Best Solution
posted on Aug 17, 2008
FixYa! (100)
midnightmove
Rank:Apprentice Apprentice
Rating: 95%, 3 votes
After clearing the jam (with the unit unplugged!), let the unit cool completely, then try using it again. A notice on the nameplate inside my unit says: "2 min on/4 min off." Apparently, a thermal cutoff keeps it from overheating by automatically preventing continued operation that might otherwise melt the parts. So heed the directions. I had the same problem with my NoviTech Model PS-026/B2 crosscut shredder (max: 5 sheets, 1 credit card). Also, make sure the motor mechanism is seated square and flush on the bin. I tried testing it out of the bin, and the green ready light wouldn't come on -- for a good reason: safety. (I still have all of my fingers, thanks to that!) Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on novitech shredder:
I don't want to Accept this solution
Best Solution
posted on Feb 26, 2008
FixYa! (100)
fellowesrep
Rank:Guru Guru
Rating: 87%, 118 votes
For user snowbut you may have plastic strippers on underside that have broken or the area holding the cutter in place on the one side may have cracked allowing cutters to move together
For user kooljay without more info you may have a broken gear or a dirty, stuck, or broken paper feed sensor.
To answer your questions better contact Fellowes Customer Service at 1-800-945-4545
Thank You!
Can you Help with these Shredders problems?
Shredders
lost power cord and am trying to buy new one!
Shredders
Thanks so much for this ... at least I didn't get to the...
Fellowes Manufacturing Powershred DM15C...
I am looking for a manual to show me how to put the unit...
NoviTech Paper Shredder Model: PS-026/B2
I had a paper jam which I have cleared but the unit will...
6 Other Users Have The Same Problem - Continued
Comment by kooljay, posted on Feb 23, 2008
will not feed paper forward
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Help us help you.
Take a brief survey and help us improve the site.
Your opinion counts!
Repair Service
Find Shredder Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
