Question about Pioneer SD-P50A3Q 50" Rear Projection Television
Will not turn back on
Was watching tv ...picture and sound excellent....tv went off...when trying to turn back on either with remote or at set....red light clicks to green and shuts off right away...will not turn on
  • Anonymous Mar 20, 2008
    i found the fuse also and replaced it/tv plays great for about 2 hours then the fuse blows again/i thought about larger fuse but that may cause bigger problem/anybody help???
    President:
  • 4,402 Answers
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Posted on Feb 12, 2008
Pop sound tv went black, went off then back on had sound but no picture, I turned it off and it turned its self back on at this time no picture and no sound. I unplugged tv and when I plugged it back in it...
An electrolytic capacitor has gone bad in you high voltage section of your TV or the high voltage oscilater has gone failed please have tech check and replace
Aug 13, 2010 | Samsung DLP HL-P5663W 56" TV
We have picture, but no sound; it is not the cable box. Suggestions?  We were watching the TV when suddenly the sound went dead.  Messing with the cables in the back brought it back temporarily,...
Try changing the cable. Is it a red and white composite audio cable or an hdmi cable? Try resetting the tv to the factory preset values. On the tv remote press the menu button and scroll over to setup. Scroll down to reset and press enter. Select yes then press enter. Select yes again then press enter. Then after the tv restarts go back to the correct input. I do recommend trying another set of cables if jiggling them did cause the sound to come back once before.
May 06, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
38 '' RCA TV XBOX Model 36V550T, lost the picture
Does it only happen when you use your Xbox?
Try pulling the cable in and out between the TV and Xbox
Dec 05, 2009 | RCA 36V430T 36" TV
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Audiosonic DVD player no sound
Try using a diferent rf cables.I would suggest that red,white and yellow colour coded RF cable is still the best.(yellow for Pictuer,White for sound and red also for sound(surround).
had similar problem than i cahnge the cables and found out that it worked with that cable...
thanx,
FIJI
Jun 21, 2008 | Televison & Video
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Bush id tv
Dear Sir, unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution. This job definitely requires a professional technician Best regards, Arpi
Jun 17, 2007 | Bush 5693D 24" TV
Pioneer SD-P50A3Q 50" Rear Projection Television Logo
278 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
