Question about OKI B4300 Led Printer
Paper jam issue
We have B4300 printer in our office, and everytime I tried to print, it jam.
the jamed paper can be easily removed from paper try (bottom of printer), but the printer says "open upper cover"
Are there anything that I can do? such as clean particular part or something??
We had the same problem in our office.We tried cleaning it with compressed air but not much was done.Finally be changed the paper we were using with a less glossy and this seems to work.The printer has a roller with some kind of glue on it that pulls in the paper and if the paper is a bit glossy it can't stick on it.However sometimes it jams but once in a while now.
Posted on Feb 16, 2009
Paper jam always.
Helo have you tried to check on the driving gears it but try to call your technician to check on it otherwise you may spoil your printer
Jun 16, 2017 | HP PSC 1610 All-In-One InkJet Printer
Jamed paperc86 paper is jamed
Epson Stylus InkJet Clear a paper jam in printer
Jan 05, 2012 | Epson Stylus C86 InkJet Printer
I keep getting paper jam messages when there is no paper jam.
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 23, 2009 | HP Photosmart C4180 All-In-One InkJet...
Paper jamed
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
I have a lexmark x2550 printer. I was trying to print a document but the paper became jammed so I removed it. I threw away the jammed paper and tried to print the document again loads of times. Everytime i...
If its not taking the paper, it may be that the paper you are using is not the right type. Some papers are too smooth or shiny to allow the guide wheels and platten ( roller) to grip the paper. This oftemn results in no paper or only one side of the paper being caught and then it jams.
Wipe the platten with alcohol, as welol as thye guide wheels if you can see them. Ink tends to stick on them and the platten and becomes shiny ans so paper will slip. Also try a heavier grade paper to see if that rectifies the problem
Aug 10, 2009 | Office Equipment & Supplies
Printer erroneously reports a paper jam
Perform a hard reset of printer and see if that clears up the situation. Also uninstall and reinstall drivers.
Sep 04, 2017 | Office Equipment & Supplies
Xerox 7750 - Jaming in fuser
Solution 1: There is probably a very small piece of paper caught in the fuser, remove it from the machine if you can and try manually feeding paper through it.
Solution 2: Try different paper. The paper may be too weak to pass through the hot fuser, and this doesn't matter you are always using the same paper company, sometimes they change their suppliers.
Follow the link below and good luck.,/?St=299,E=0000000000024640321,K=7426,Sxi=18,Case=obj(20159)
Also check this link if there is a grinding noise as well as the jam.,/?St=299,E=0000000000024640321,K=7426,Sxi=18,Case=obj(21995)
Dec 04, 2008 | Xerox Phaser 7750DN Laser Printer
replace the ink cartridges first... could be just a cartridge issue...
do a print head cleaning... refer to your user's manual for step by step instructions on how to do a head cleaning on your printer.
Aug 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Oki b4300 Led printer misfeed.
No worn picker cause it is getting past paper rego area and stopping at the fuser.Check to see if bottom fuser roller (orange rubber one under metal one) is wrincled or the plastic coating is coming off to the side
If not then one of the paper path switchs is sticking sometimes down and not springing back (common)  when paper has exited area.there is 3 or 4
Oct 18, 2007 | OKI B4300 Led Printer
Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Aug 22, 2007 | OKI B4300 Led Printer
OKI B4300 Led Printer Logo
353 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
