Question about Canon S520 InkJet Photo Printer
Canon s520 problem
Wont run flashes yellow 4 times and green then 4 yellows. Can I fix this?
  • 3 more comments
  • Kennicol Apr 02, 2008
    Printer won't run. It flashes orange 7 times then green and keeps repeating this sequence. What do I do?
  • Anonymous Apr 30, 2008
    Flashes green once, then yellow seven times.
  • Anonymous May 19, 2008
    Flashes yellow four times then green once.
  • vstadelq Jul 27, 2008
    S520 about 5 yrs old. In daily use and has never missed a beat. Makes short grinding noise (grrr...grrr...grrr) when turned on and flashes 4xorange. All ink tanks full. USB drops and reconnects when turning off (ding-dong... dong-ding). Running on XP.
    Can you help?
  • bginnings Aug 05, 2008
    Try to print. Blinks 4 orange lights then green and repeats over and over. Tryed to unplug for 10 minutes, checked the ink carthrages and they are ok. What next?
I solve mine (4 Yellow Flash + 1 Green) by pushing on the white gear, located at the end right inside, where the cartridges are cleaning. This help the movement of the gear, it was stuck or gem. Do this when you just turning on the printer, then you ear the cycle noise, Your fingers will sense the movement of the gear. Tips: Push the cartridges block to the left to let you enough space to put your hand inside.Now it work normally.
Posted on Apr 23, 2009
Flashes yellow 7 times. Tried everything I could think of. Uninstalled Canon S520, reinstalled CD. Turned off and on, took out power and replaced cords. I have tried "resume" printing, but noticed some locations are still on "pause".
No paper jam, new ink cart.'s. Took them out and put back in.
Help!
Jim
Posted on Mar 03, 2008
My S520 was giving 7 blinks. I took out the printhead (pulling up on the Grey lever). When I put it back in it worked fine.
http://www.fixyourownprinter.com/forums/inkjet/23041 lists some of the blink codes for the s520.
Posted on May 20, 2008
I am lose my driver disk
  • menem hamed
    menem hamed May 20, 2008
    i lose my driver cd for canon s520 are you help me for thes
Blinks green, yellow, green yellow
Anytime it flashes green and yellow there's a service error, but you need to count how many times it flashes between the longer green flashes, that tells us the error code.
Oct 28, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
CANON I350 DOES NOT PRINT
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
Cannot get my canon to respond. Has worked fine in the past. I push to bring online and the light still blinks yellow.
Your machine does a longer green flash and then a series of orange flashes and then green again. I need to know how many orange flashes between the greens to tell you the problem..
Aug 03, 2009 | Canon S520 InkJet Photo Printer
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon S400 lite binks 6 times won't print.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Dec 27, 2008 | Canon S400 InkJet Printer
Printer is not responding
This is the error light page from the S520. Not sure about this, but probably the same on the S530. 8 Blinks means replace the ink absorber and reset the counter. I think the ink absorber can be gotten at from the bottom, BUT NOT SURE. Try this at your own risk!
7.1 Service Mode Operation
1) With the printer turned off, hold down the RESUME button and press the POWER
button (the green indicator lights and the desired service function can be selected).
2) While holding down the POWER button, let go of the RESUME button before pressing
the RESUME button again twice in succession. Then let go of both RESUME and
POWER buttons.
(At each press of the RESUME button, the indicator toggles between orange and
green.)
3) During printer initialization, the green indicator blinks. When the green indicator
stops blinking and remains on, press the RESUME button the specified number of
times to execute the desired service function, as listed below.
green.)
Press Indicator Function
0 times Green Power off (Even if there is no print head mounted, the
carriage will return to the home position and lock.)
1 time Orange Service/factory test printout (Including ink sensor check)
2 times Green EEPROM information printout
3 times Orange EEPROM initialization
4 times Green Clears the waste-ink counter (S750/S520)
Waste-ink counter settings (S900/820) (See page 2-34)
5 times Orange Destination (model) setting
After reaching this service function, press the RESUME
button the number of times specified below to set the
destination.
Setting
0 times BJ F900 BJ F890
1 times S900 S820 BJ F700 BJ F500
2 times BJ F890PD S750 S520
3 times S820D
Note: pressing more than 3 times has no effect.
6 times Returns to the function select stage (S750/520)
6~9 times Not used for servicing (S900/820)
More than Green Returns to the function select stage (S900/820)
10 times
4) After selecting a service function, press the POWER button. The green indicator
lights and the service function will be executed. (After each function is executed, the
printer returns to the service function select stage.)
READ THIS CAREFULLY !
Larry
Nov 30, 2008 | Canon S 530D InkJet Printer
Canon S520 blinks 7 times yellow then once green over and over, won't print
Read the info on the link below:
Solutions for flashing lights Issue: Alarm / Power light flashes orange 7 times consecutively (Print head error)
1. Reseat the print head S520 / S750 2. The Print Head may need replacing - S520 3. The S520 may require repair
spacer.gif http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=231&modelid=6611
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 17, 2008 | Office Equipment & Supplies
Flashing green light prevents printing.
hi!!!!
try to pull out the cardtridge and put it back properly
sometime the cartrigde is place properly on the printer!!!
try to email me ronaldsuboc@gmail.com
Aug 08, 2008 | Canon S520 InkJet Photo Printer
Canon S520 InkJet Photo Printer Logo
1,157 people viewed this question
old marine
old marine
