Question about Ovens
Gas oven - - melted plastic inside
Last night when the oven was on and I noticed a smell coming from the oven and it turned out to be a blue plastic lid had fallen down and it has now melted inside the oven - - how do i fix it?
i have been able to remove most of the plastic that is visible - - but what if some of the plastic oozed into the holes on either side of the bottom of the oven? could this cause an issue if I were to turn the oven back on for use? Please advise. Thanks!
  • 5,911 Answers
You can remove the bottom oven panel and look under it. All you have to do is remove the oven racks and locate the screws that hold the bottom panel in place. MOST ovens only have two of them. Once you have the crews removed, the panel slides back a bit, then lifts up. If there are any heavy deposits of melted plastic, remove it like you did before. Any residual material can be taken off with some fine emery paper. Wear a dust mask and vacuum all the dust out of the oven. DO NOT use this method on the oven wall as it may scatch it. This is only for anything that may have dripped below the oven pan. You may have an odor to the oven for a while, but as long as you have nothing else melted inside this should go away. Try running it on a cleaning cycle AFTER you've inspected the oven & cleaned out the remaining plastic. This will burn off anything left behind. I hope this helps you.
Posted on Feb 12, 2008
  • Danielle Randall
    Danielle Randall Apr 24, 2014
    Ha, another person who doesn't read directions.. You didn't remove the packing... You realize this is unser negelect, and NOT the manufacture defect. Someone didn't read directions, then plays the blame game. Get as much as you can off without damaging your oven walls, then run a selfclean.
The plastic ties were left on the oven rack. One melted . How do I get the plastic off the bottom of a self cleaning oven?
Warm Method Both Good Housekeeping and the website Hunker describe this method for self-cleaning ovens. Hunker warns to NOT use the "cold method" which is reserved for other types of ovens. And the Good Housekeeping site says if the method proves unsatisfactory, that the floor or bottom plate of the oven might have to be replaced.
(That said, I suspect if you pull out oven racks and apply some ice to any plastic on it, the plastic might become brittle enough that tapping it with a spoon and prying at it with something wooden or finger nails might remove a lot of it. No scraping with the spoon!)
Here is the primary process for the oven.
Self-cleaning ovens require heat to remove the melted plastic. This method also works on heating elements with plastic on them. Step 1 Turn the oven on to the lowest heat setting. Only leave the oven on long enough to make the plastic soft and pliable.
Step 2 Scrape the melted plastic with a wooden utensil such as a spatula or spoon. The wood protects the surface inside the self-cleaning oven. When you get all off that you can, the self cleaning feature may burn off the rest. That WILL be smokey and exude an unpleasant smell while it does it. Open windows and keep pets out of the area (and yourself) while it goes through the clean cycle. Do NOT use a screw driver to try and remove the plastic.
Aug 26, 2017 | Ovens
Magic Chef wall oven does not turn on after there was a fire in the oven.
I would get an appliance engineer to check/repair it, if a repair is possible.
May 06, 2017 | Ovens
Popping noise, flames between oven and wall and burning plastic smell from Kenmore gas oven. We had noticed the smell off and on for 2 months, but the oven still worked properly until last night. I...
sounds like the insulation on the cord has been worn through and is shorting out. turn off the breaker pull out the oven and look where the cord goes into the oven and look for black burn marks.
Apr 09, 2017 | Kenmore Ovens
Our Viking oven (approx. 8 or 9 years old) seems to be taking longer to preheat and we have noticed a gas smell when the oven is on. Last night, it took at least a half an hour to reach 350.
What type of Gas do you have?-- Natural Gas?-- or Bottled Gas?
The reason I ask, is that If your gas supply is in a tank,-- the tank might be low..)
If you have Natural Gas, and you suspect that you smell gas, You can call your Natural Gas supplier, and have them check for leaks.
So-- If you know you do not have a low gas tank, then you need to call your utility first.
Mack B
Jan 10, 2011 | Ovens
My oven won't turn on. the burners work, but when i turn on the oven, nothing happens, no gas smell or sound... no heat. the night i noticed it, i turned it to 450 and an hour later it was lukewarm, then...
Where the pilot light for the oven is located is a bulb that keeps the gas on. It is called a thermocouple. These get old and fail. They are easy to replace if you have some basic tools and mechanical ability. They are usually not too expensive-around $10-20.
Dec 20, 2009 | Ovens
Oven - Very bad gas smell
Very Dangerous! turn off supply to appliance, supply ventalation and call service tech. If you are very familiar with gas appliances and know what you are doing then you can try to locate the leak using soapy water or leak detector liquid. make sure all flames and other possible sources of ignition have been eliminated. Keep room well ventilated. Spray leack detector on all fittings and look for leaks replace or tighten parts as needed. This responce is asuming you have not blown up already, seriously dangerous situation you have there.
Jan 07, 2009 | Ovens
Oven gas
For safety purposes call gas technician to check your gas pipe. If stove turn off supposed not to smell gas.
Jul 23, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ge gas oven
Remove the burner tube that you said has soot on it and clean it out. This will give you a cleaner burn.
Jul 20, 2008 | Ovens
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Ovens Logo
532 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
