Back to:
Tags:
Projection Televisions
Generic problem for all Projection Televisions
Samsung big screen color problem
posted by acutforu on Feb 12, 2008
the colors are not aligned, when i go to the convergence menu, the blue will line up but the red won't move, and the red is the real bad one. I have tried turning the t.v. off and unplugging it .
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 12, 2008
Helpful (85)
willtab
Rank:Guru Guru
Rating: 89%, 399 votes
this is an indication of the convergence ic or at least one have gone bad. it also could be convegence ouput resistors
Rating Locked! (?) acutforu has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on samsung big screen color problem:
I don't want to Accept this solution
Can you Help with these Projection Televisions problems?
sagem axium hd-l32t/2 slow start up
NS-LCD15 powers on but no display
Sony Grand WEGA KDF-42WE655 42 in. Rear...
I have experienced very distinct vertical green lines that...
I ahve chnged the bulb because my screen started flashing,...
lg plasma model42PX4DV television set.Picture gone but...
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
