Question about Sony Cyber-shot DSC-W70 Digital Camera
Flashing error signal
Flashing error E:91:01. Please help
  • thewalmax Mar 03, 2008
    My DSC_W70 fell down, since then the flash do┬┤not work and appear on the scream th error E:91:01... I reseted my camera but still has the problem
  • haasbroekm Aug 18, 2008
    i also have the same problem. the following message appears on the lcd screen. E:91:01.
    i have done the whole initializing thing and the message dissapeared but another yellow light iwas now flashing and the flash is still not working.
Seems in a drop or knock flash board might touch metal and short out. When camera gets that error usually the main system board needs to be reset and it seems only trained service technicians have access to tools required to do this
Posted on Mar 21, 2008
INFOCUS IN102 PROJECTOR LIGHT BLINIKING
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Aug 02, 2017 | Cell Phones
I get a flashing E-1 error code
I keep getting the flashing E-1 error code...
In the manuel for trouble shoot I do what it ask and there's no change. It will run for 2 or 3 minutes then just start flashing " E - 1" code. Need help Please.
Jun 08, 2010 | Whirlpool GEW9200L Electric Dryer
The "!" light is flashing; two of the print heads are flashing; I send a drawing to be printed; and nothing happens.
The flashing lights signal an error. If the printer started printing, please check for jammed paper. If it has not started to print, please remove the ink cartridges and then put them on again. They might just failed to be charged by the printer unit.
Feb 02, 2010 | HP Designjet 110plus nr InkJet Printer
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Fault
If you still can print, it signal's low ink. If it flashes immediately as you turn on the printer and nothing's happen with the printer or no movement or unusable due to error flashing, there is an error either with your ink cartridges (need raplacement) and or hardware mechanical errors. Hope this helps.
Best regards,
Rosener
Feb 05, 2008 | Office Equipment & Supplies
Printer
How many times it flashes?. It flashes in Orange or alternately in Orange/Green. This flashing LED has certain count that indicates the error occurs in the printer. To find out how to identify error indicated by flashing LED, please check here ;under article How to identify error indicator. Please tell me soon after knowing how many times the printer LED flashing.
Regards,
Jan 04, 2008 | Canon S400 InkJet Printer
Sony Cyber-shot DSC-W70 Digital Camera Logo
234 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
