Question about Jenn-Air JES9800A Electric Kitchen Range
Stove will not work keep saying f3 lonf beep will not turn on
  • franG May 25, 2008
    f2 continues to beep and the oven will not stay heated, it works in the cleaning mode, the oven get hot and goes off immediatley and goes back into the F2 mode
  • 5,911 Answers
"F3" indicates an oven temperature problem on Jenn-Air models. This is usually caused by a bad oven temperature probe. It will be mounted on the back of the oven wall (usually in the upper right or upper left corner). To check the probe, unplug the range and remove the back panel. There will be two heat insulated wires coming from the oven probe behind the oven. A resistance reading at room temperature across these wires should be around 1100-1200 ohms if the probe is good. If the reading is too low (shorted) or too high (open), replace it. However, I would take a good look at the interconnecting wiring FIRST. If you have a connector plug on the oven probe, often the plug pins will oxidize and not make good contact. This gives false readings and leads to error codes. Some manufacturer's recommended cutting the connector plug off completely and hardwiring the leads together by using heat resistant ceramic wire lugs. These can be purchased at most hardware stores. A new oven probe costs about $43 and can be found on line at several appliance parts websites. I found it at repairclinc.com (item #1364). Just type your model number in the search menu and a pictorial part index will be provided. I hope this helps you
Posted on Feb 12, 2008
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
F3 on stove. Can't turn off
Hi Marie -
Since you didn't mention the brand and model of your stove - I can only offer general help. The first thing I recommend is that you shut off the power to the stove at the circuit breaker panel. It should be a double-wide 40 or 50 amp circuit breaker. Move the handle to the OFF position and leave it there for 30 seconds or so. Then return the handle to the ON position again. Doing this should "erase" the memory of the stove and reset the electronics. If the problem is not longer an issue - the F3 code should be gone. If it returns, we'll have to do more. That will require knowing the name of stove's manufacturer and model number. Let me know how you make out and if you need more help - provide the info requested and I'll see what else I can do. Good luck!
Mar 18, 2014 | managemylife.com
My wife used the self clean feature on our gas stove an now it keep beeping and showing the f3 code how do i make it stop cause the stove wont even turn on
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 22, 2010 | Ovens
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Continuous warning Beep & "F3" displayed.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Jul 22, 2009 | Kenmore 95822 / 95824 / 95829 Electric...
F3 error light
Hi thanks for the question. the f 3 code says the oven sensor is open. that's the part located in the oven. top left in oven .cut the power to stove . replace the oven sensor thanks the appliance doc
Sep 06, 2008 | Frigidaire FEF366 Electric Kitchen Range
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Jul 25, 2008 | GE JE1460 Microwave Oven
Jenn-Air JES9800A Electric Kitchen Range Logo
232 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
