Question about Gateway FPD2275W LCD Monitor
Monitor not powering up
I have a Dell 19" Monitor, I recently have run into a problem where it takes my monitor 30minutes to an hour to "warm up" before receiving a signal. This only has started happening over the past couple of days and think it might have been from the recent freak electrical winter storm that we got. The power was knocked out a couple times that night. The cpu works fine but there seems to be possibly a fuse issue with the monitor. Any thoughts would be greatly appreciated.
    Problem Solver:
I'm not too sure about dell pc's.But if you think a fuse might be inside there,I'd try to do a search online for how to change that and go from there.However,I'm not really understanding the warm up thing.Is it an LCD screen?
Posted on Feb 13, 2008
Monitor wont turn on. Message state " entering power saving mode"
Try to reconnect all cable of your pc then your ram then bring it back make it sure it is set up ..then then try to turn it on or wait for 30minutes
Jul 11, 2011 | Dell E173FP 17" LCD Monitor
My dell in1910n monitor goes into power save mode and I can't access anything. How do I fix it if I can't get to control panel?
Right click on an empty area (not on an Icon) of your desk top and select properties.
Select the Screen Saver tab.
Click on the Power button in the lower right corner.
Use the Turn off monitor: pull down menu and select never. You may want to set the other parameters to Always On for Power schemes and never for System standby: to never. I set my power scheme to the above settings, since I work with photos and graphics and the color will change as the monitor warms up.
Jun 28, 2010 | Dell IN1910N 19" Monitor
Can't get monitor out of energy save mode
you talk about a dell monitor but categorised under LG monitor... if it's a Dell monitor, and its recent, it's possible you've put it in analog/digital mode when you need the other mode. push the left button on te front of your screen that should switch your screen from digital to analog or vice versa
Dec 28, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Dell 22' monitor Black screen Green light stays on.
well i have a dell 22'' monitor and it did exactly the same thing , turns out its a fault with the invertor drive transistors ( these power the fluro screen light ) , i'm in the uk , but i would take it straight back to walmart along with proof of purchase and tell them it dont work and ask for a repair /replacement under warranty
Nov 17, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
The bottom green is flashing and not vision, and do not turn off
This is most likely the power inverter board in the monitor, especially the Dell 19". If it started taking longer and longer todisplay an image, and the power light is blinking on-and-off, that'smost likely the problem.You can confirm that it's actually the monitor and not your computeror the cable by plugging in another monitor if you have one to try. Ifit's under warranty, send it back, if not, there are inverter boardsfor many common models of LCD monitors2.gif that are replaceable. The boardcan run anywhere from $50 on up. Depending on how old your monitor is,and how much you've invested into it, you may find it better to justreplace it with a gently used one from ebay.
Oct 20, 2009 | Dell E193FPC 19" TFT LCD Flat Panel...
Monitor shuts off
The labor rate in the midwest where I live is $50 just to look at it. Unless you have electronic experience and test equiptment, I do not believe you wil be ableo to service it yourself.Usually cheeper just to buy another replacement one.
Feb 17, 2009 | Dell M992 19" CRT Monitor
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E193FP Problem
Probably a failing power supply
Apr 17, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
19 in Dell flat panel monitor
also need to see video how to remove back of monitor case
May 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Gateway FPD2275W LCD Monitor Logo
136 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
