Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
1994 Zenith 52" projection TV
I was given the TV, and Yesterday was the first time to clean the mirror, and red,blue and green lights, plus adjustment. Picture is great. The only problem I have is when you turn on the TV sometimes there is a offset blue color. to the right, predominant about 6". If I turn the TV on and off sometimes allot, sometimes just a few. it comes back to alignment. What could be the resolution?
techman
  • 3130 Answers
SOURCE: MY ZENITH MODEL # Z60Z83R8 BOW'S VERTICALITY
You have a problem MOST LIKLY!!, that happens to almost if, not to all projection tube sets ever made. Its the old bad convergence IC falure. It's not something you can do unless you have had exstensive electronic training and soldering skills. There are no user replaceable parts inside of this set so please call out a pro to repalce the convergence IC for yop! A repair such as this should cost around 250 to 400 bucks, depending where you live..Good Luck
Posted on Aug 04, 2006
Slinteriors
  • 8617 Answers
SOURCE: 1999 zenith 52 inch rear projection screen t.v.
IS the screen white retrace lines ? Have you looked into the CRT lenses while they are on with a signal applied through the input to see if an image is displayed in the lens lens of the crt? Let me know what the answer is to these two questions and we will go to the next level.
Posted on Apr 10, 2008
  • 556 Answers
SOURCE: zenith projection tv convergence proublems
YOU HAVE BAD CONVERGENCE IC'S AND POSSIBLY SOME LOW OHMAGE RESISTORS THAT FEED THE IC'S.
Posted on Sep 14, 2009
johnnydiode
  • 647 Answers
SOURCE: Need a red bulb for Zenith PVR5263RK rear projection tv
It sounds like your looking for a CRT (red) the part # is on the CRT and could be puchased through any Zenith (LG) distributer- usually around $300- $500. Google the part # when you get it and you may find a used Picture Tube (CRT)for cheaper.
Posted on Sep 22, 2009
SOURCE: blue spot on tv screen
Better yet watch it till it completely dies and then pitch it! It costs more to replace the light engine than it would to buy a new tv....I will be putting on in the layaway soon!
Posted on Apr 03, 2010
I have Zenith rear projection TV Model IQC60H95W.The blue tube does not work. The red and green project. Is this a bulb or tube and are they available to purchase? The TV was made in 2001
This is a CRT(cathode ray tube) not a bulb. A Bulb is totally different. If you replace one Tube, you need to replace all 3 or the colors will never match properly. However, This model no longer has parts available. Even if they were, the cost would be close to $1000 in parts. I would not recommend repairing this TV.
Sep 14, 2014 | Zenith Televison & Video
My tv is blue. no red & green
Please check if the red and green tube have lights.Then if the green and red tube have no lights the problem is in the driver board of your tv.It is a major repair and need to check the repair technician.
Jul 06, 2011 | Zenith Televison & Video
What causes the picture to have a green tint
there are 3 color cathode in your TV red,green,blue cathode.The red and blue cathode might not working in your set that is why you have a green screen. Open the back cover of your TV you can immediately see the 3 cathode lamp at the back. Clean the lamp first using a clean clothe. Power up you tv and see whether the 3 lamps are lit. If lamps do not light up,check the circuit board where this lamp is connected re-solder all the components in this lamp. There is also an individual screen adjustment for the lamps it is located at the front panel and labeled RGB screen...try this first and let me know how it goes..
Apr 16, 2011 | Zenith E44W46LCD 44" Rear Projection...
Red green and blue colors seperated
convergence settings buddy normal tv repair for under 100 dollars its a normal thing should be adjusted every 3 years but some tvs can last 10 years or even longer or sometimes less than 3 years its just your luck
Mar 10, 2011 | Zenith D52WLCD 52" Rear Projection...
I have a Zenith 65 in. TV model #R65W28 serial #271-33220211. The words are blurry and there is a green outline on images in the picture even if i reduce color to black and white. what can i do to fix it?...
It sounds like the convergence drive circuit has gone bad. When that circuit goes the red, blue and green don't line up properly. Have a repair shop check it out. While they are in there have the shop clean the lenses and mirror.
Oct 16, 2009 | Zenith R65W28 65 in. Rear Projection...
Blue area on the right and left bottom corners
If this tv is a projection tv it is the blue polirizer. It is a mirror that is fitted in the lighthouse. Very cheap but agent try to sell hole lighthouse that is more expensive than sechondhand tv.
Jul 11, 2009 | Zenith D52WLCD 52" Rear Projection...
52 Inch Zenith TV has red blue and green squiggly lines what is wrong, no picture
I belive that the red light means that it is off and the blue means that its on
Jun 10, 2009 | Zenith D52WLCD 52" Rear Projection...
Red color gone on tv?
is the red gone on all inputs? do you have the tv hooked up, to a sat box, cable box via component video (Red, blue, green connections)? if so check the red cable on both ends.
Jan 29, 2008 | Zenith D52WLCD 52" Rear Projection...
Rca guide plus gold 52 in projection tv
sounds like the blue CRT is contaminated open the back turn on the tv look into the blue gun if it looks snotty the coolent needs to be replaced
Oct 31, 2007 | RCA P52926 52" Rear Projection Television
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
