Question about Sewing Machines
Singer Concerto sewing machine model 9217
I have bought a new bobbin case and still I have a problem. The top thread catches and winds under the bobbin case . I am sure that it must be just an adjustment I need to do but can someone pleeease tell me how?
thanks in advance.
Tracy
  • 3 more comments
  • Tracy475 Feb 19, 2008
    I am sure all my bobbins are genuine singer self winding ones and I have been careful to seat the bobbin correctly. There is no lint. Problem still not solved - any further suggestions please.
  • GOLDENGIRL55 Jul 29, 2008
    I HAVE AN PROBLEM WITH THE SAME MODEL 9217 SERIAL NO. N614814115. I CAN NOT GET IT TO CATCH. IN OTHER WORDS THE BOBBIN WON'T WIND. I HAVE TRY VERY HARD AND VERY CAREFUL IN MAKING SURE IT'S THE RIGHT BOBBIN AND PUT IN RIGHT. IT JUST WON'T WORK. THE EXAMPLE YOU GIVE IS NOT AN GOOD ONE. PLEASE HELP ME. I NEED MY SEWING MACHINE. I DON'T WONT TO HAVE TO BUY ANOTHER. THANK YOU. BARBARA
  • troy038 Sep 30, 2008
    I have the same problem as Tracy475. I haven't replaced the bobin case, and I am sure the bobins are the correct ones.
  • japey78 Jan 22, 2009
    i also have a 9217 singer and it will not catch the bobbin thread, ive been trying for the last 40 mins, please help!!!
  • app_3rp13717
    app_3rp13717 Feb 06, 2013
    Can be fixed in 2 minutes by repair person at a sewing shop. The problem is under the bobbin case that lifts the case so the bobbin will thread.
  • 3 Answers
I was having the same problem. try putting in a new slide plate - the pressure from it holds the bobbin down, but it wears thin after a while. fixed mine.
Posted on Mar 03, 2009
  • trina
    trina Nov 20, 2013
    did u think thats a problem?? the model of my singer machine is 188u.
  • Sewing Machines Master
  • 1,388 Answers
Are you certain you are using a singer bobbin to suit this machine ?
If you have gathered a collection of bobbins over the years and have just grabbed "any old one" it may have different depth and diameter.
If this is the old 9217 that has a self winding bobbin, it is even more important to get it right.
It is almost always necessary to match the bobbin to the machine to avoid problems.
Also ensure that the bobbin is sitting comfortably, not at any angle, and that the hook race surrounding it is clean and free of lint deposits.
Singer UK has a few diagrams & info that may be helpful ....here
Posted on Feb 17, 2008
Singer 9217 thread winds under bobbin instead of on bobbin
Make sure the bobbin is seated all the way on the winding pin. There may be an adjustment for it--a technician can probably fix it for you. However, you can also try lifting the thread with a pencil tip just before it winds onto the bobbin. Some of my machines wind the thread unevenly (more on the bottom than the top of the bobbin) and I balance it out by lifting it when winding.
Oct 07, 2016 | Singer Sewing Machine 9217
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
Threading problem
Hai, you check the bobbin tension.
Mar 21, 2014 | Singer Sewing Machine 9217
How to thread a bobbin
Which Singer machine do you have? I know how to wind and insert a full bobbin for some models.
Some wind the bobbin with it in the case. This is the case with my Touch & Sew. Inserting a full bobbin is simple. Open the slide plate and drop in the bobbin with the rings up. Make sure that to hold the bobbin thread so that it comes off at the left. Then close the slide plate and make sure that the end of the bobbin thread is coming through the notch. Hold onto the threads and turn the handwheel until the top and bottom thread come back up with a twist. To wind a bobbin for this machine, open the slide plate (some models have a little mark to line up the slide plate). Put in the empty bobbin and thread the top normally. Set the machine to straight stitch and push the bobbin wind button in. (This has a bulls-eye symbol on it.) Wrap the end of the top thread around the presser foot screw several times and hold onto the end. Step on the foot control to start winding. Keep winding until the bobbin is full. The thread wound onto the screw should break. Pull some extra thread and cut it to separate the top and bottom threads. Close the slide plate and set your desired stitch.
Other models are wound at the top of the machine. For some of with a drop-in bobbin, you need to bring the thread down to a catch and then off to the left to another catch. Some have a vertical bobbin. I don't remember if they all have a removable case. Those that do need the thread to come through a notch on the case that pulls the thread under a spring that keeps the bobbin tension. However you should check your manual. If you do not have a manual, check if one is available online. (http://www.singerco.com/accessories/instruction-manuals has many of the Singer manuals for sale or download.)
If you post a comment with the model of your machine, I'll give you a description of threading the bobbin or winding one.
Jan 19, 2012 | Singer Sewing Machines
Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Feb 16, 2010 | Singer Sewing Machines
Singer Concerto 9217 - problem threading bobbin
thread the same way as for sewing. put empty bobbin case in bottom. close slide plate only to red button, not all the way. wrap thread from needle around bolt that holds on the presser foot (or just hold it tight). press pedal to sew. bobbin should wind. when done, shut slide plate all the way and sew.
if this doesn't work, try using a pin to push down the center of the bobbin when the slide plate is in winding position - the little catch on the bottom of the plate breaks easily and then the bobbin won't wind without a little help.
Feb 01, 2009 | Brother CS-8060 Computerized Sewing...
Singer Concerto sewing machine model 9217 - bobbin thread problem
This problem is common in sewing machines with plastic bobbin cases. The new case you've ordered will most likely solve your problems. I might suggest checking the point of the rotating hook, to be sure it is burr free.
Jan 31, 2008 | Sewing Machines
Bobbin is not winding correctly
slide plate may be worn - i had the same problem. try holding down the center of the bobbin with a pin while slide plate is in the winding position.
Dec 31, 2007 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
1,676 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
