Question about Norelco Advantage 6705 X Electric Shaver
Won't charge up, won't run
I think I have destroyed the charging circuit in the razor. I pushed the on-off button while the razor was charging in its charger. The razor is now dead and will not charge.
The charger shows an AC output of +/- 10 VAC under no load, so I assume it to be OK.
I plan to connect two AA's to the motor to see if it is still OK.
Are charging circuits available for this razor?
TIA,
Bill Edwards
  • Bill-E Feb 12, 2008
    U sure? The input connections on the circuit board located under the batteries in the razor feeds what looks like a small full wave bridge rectifier. This also appears to be short circuited.
    Since all the devices on the circuit board are epoxy covered, it is hard to tell what anything is and the charger itself is a small black epoxied cube. That's why I asked if the circuit board was available.
    The motor is fine and runs OK on a couple of AA's.
    Bill-E
  • Anonymous Mar 11, 2008
    charger is getting blue crust around contact points is there a solution i can use to clean the contact points????
    Sergeant:
  • 319 Answers
Uh...the charger's supposed to have a DC output
Posted on Feb 12, 2008
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
May 22, 2016 | Tablets & eReaders
Razor electric scooter e 300 battery charges but won't run
first check to ensure the batter has held the charge you put into it. Just plugging the charger in does not mean the battery is holding the charge. If the battery is bad, it will drain as fast as you put it in. if the batter holds a charge, should be able to disconnect the charger and battery will show charge. if so, you have a bad connection or motor.
Jun 29, 2013 | Motorcycles
Bella won't charge
check it with a multimeter and make sure that its putting out the correct amount of volts, it should be at least 24 volts
May 21, 2012 | Razor USA Razor Pocket Mod Electric...
Razor Bistro scooter won't take charge - light stays red
i had the same problem with mine and it ended up being that one of the batteries was bad, there are two 12v batteries wired in series under the seat, usually you can tell which one is bad by looking at them, one of the batteries will be swelled up
May 09, 2012 | Razor Pocket Mod-bistro Retro Scooter
My razor dune buggy won't drive
are you sure that the charger is putting out enough volts to charge the batteries? check the charger with a multimeter, then check the batteries with a multimeter, and viually inspect the batteries for bulging
Apr 28, 2012 | Razor Dune Runner 350 Go Cart
I have a vpc-E1500tp and it won't turn on and it won't charge... What do I do?
Lens is not all the way extended, so you can not turn it on. the defect maybe fixed buy pushing on the power button and pull the lens out gently by wiggling the lens? It may all be futile. Buy a new camera.
Mar 30, 2012 | Cameras
9595 Charger won't charge while in stand
Your charging and cleaning stand is faulty. They are not repairable because parts are not available. You can purchase a new clean and charge stand at shaveroutlet.com
Braun Series 7 and Pulsonic Clean Charge Base
May 21, 2017 | Braun Shavers Male Pulsonic System 9595CC...
I reinstalled XP on IBM T41, now battery won't charge. Could this be Driver Problem
Sounds like you need a new battery.
It's not just a battery in a case, it also has a small circuit board inside to control the charging etc, if that's faulty it won't charge, or if it has dead cells in it won't charge.
Feb 08, 2012 | IBM ThinkPad T41 Notebook
My unit won't turn off.
I have a Remington electric razor fully charged and it won;t shut off unless I plug it iin. When I remove the plug in cord it runs all the time?
Dec 14, 2009 | Remington MS5500 Electric Shaver
Norelco Advantage 6705 X Electric Shaver Logo
448 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
