Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport..vibrates during spin and "walks"..on pedistal.sitting on tile
Hi..have a new whirlpool duet sport front loader..but when it spins..vibrates a LOT...and even walks....
had a service repair company out twice...replaced the pedistal...but did not help...
can I put something under it...ie rubber supports under the feet?
or some other solution..?
thanks in advance DON
  • suzhula Apr 13, 2008
    Love the machine, however my walks 8 - 10 inches from the wall. I have tile floors. Repair people come out again to install anti vibration pads, it this does not help, guess washer and dryer go back.
  • Anonymous Jan 03, 2009
    My front load whirlpool duet sport washer rocks like crazy!!!! why?
I just bought this washer and had two problems with it. 1 the vibration at medium spins and 2. a squeeking spring (every time the drum rotates a little squeek, but when spinning the squeek sounds constant.
What I discover in solving both my problems with the same solution. I had to ensure all 4 feet well on the ground and that the top of the washer was perfectly level. At one time I was out only about 2 mm on one side, but the bubble was slightly to one side on the level but still in between the level's markers. I tested with a load, and both problems were still there. Turn feet 1/2 turn on the side needing adjusting. Ran another load and you guessed it, no squeak, no vibration, spinning was quiet, I had to go over to check to see if the machine was going through the cycles. I couldn't believe that a few millimeters could make such a difference.
Now I am pleased with the performance, not to mention how clean the clothes are and the savings on water and drying.
Posted on Mar 04, 2009
I had this issue, it would rock 3-4 inches on each side,
Make sure that the feet on your washer are as close as possible top the base, and ensure that it is level.
I had my feet extended almost full on a couple corners, this unbalanced the machine causing it to rock, also, make sure that it is on solid ground, no carpet or pads, other than those on the feet.
Happy new year...
Posted on Jan 03, 2009
  • 552 Answers
No soft things under it!
You need a solid floor to place it on, otherwise you will forever have that problem.
Were the shipping supports all removed?
I know of someone who had this problem and the shaking was real bad.
There are bolts and foam padding usually for shipping.
Also, leveling and making sure the machines 4 feet are planted solidly on the floor. If one of them is not making contact with the floor, it will rock and move.
Posted on Feb 12, 2008
My whirlpool Duet 9750 takes a long time to spin out and has a difficult time trying to balance
I owned a Whirlpool Duet and had spin/balance problems when I washed heavy and light items together. During a deep freeze my drain hose froze. Did everything I could think of until I ran hot water through washer. It took awhile to thaw. If your floor is weak, you will have a lot of vibration and walking. Hope this helps.
Dec 28, 2011 | Whirlpool LSW9750 Front Load Washer
Washer balancing load, during spin cycle wasker shakes and walks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Mar 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
My whirlpool duet gets to the spin cycle and gets to the super, fast speed and starts to shake Is there anything I can check before getting a repair person involved?
is it on a pedistal? pedistals tend to male it worse due to the raised center of gravity.
make sure the feet are adjusted correctly and is sits squarly on the ground. Is it new? did whoever installed it remove the bolts that are installed for transportation?
Feb 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Major shaking during spin cycle
I have the exact same washing machine with the same problem. It is a poor design and Maytag knows it. We should be entitled to a refund. This was a very expensive machine.
Apr 13, 2009 | Maytag Neptune MAH6700A Front Load Washer
Whirpool Duet "walking"
Hi, most of the time this can be a simple as a overload that will dramatically shake this type of washer. due to its front load design, it is recommeded to load accordingly to specs. overloading this type of washer will induce walking/excessive vibration during the spin cycle.
Mar 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer vibrates during spin cycle
Front loaders have to be situated on solid flooring such as a basement or they will vibrate.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is "walking" during the spin cycle
I have the same Duet that vibrates heavily during spin cycle. Leveled the unit with no success (our unit is mounted on the high base). Long story short, I went to Lowes and purchased a package of 4"X5" self stick foam rubber pads called Grippers by Wasman Consumer Group and paid a low price of $3.50. Since the washer walked forward, I cut one of the two Pads in the package in half, removed the sticky side paper protector and centered a half, sticky side to washer pad, to each front washer pad. The problem was solved.
I made sure the round floor pads of the washer were tight and the unit was level before attaching the Grippers. Hope this helps.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
In less than 2 weeks we had to have our new Whirlpool Deut Sport ht replaced because it literally beat itself to death. The 2nd machine had a failed computer board and after replacing machine still beats...
All washing machines rattle and vibrate during a cleaning cycle, and especially more so during the rinse cycle.
If you have placed it not a pedestal, make sure that the pedestal does not have wheels, or thin legs, as it will invariably move. It is best to place the unit directly on the floor itself.
If you still find that the unit vibrates excessively, it could indicate a faulty bearing on the drum, and I'd recommend getting it replaced once again under warranty..
Jun 12, 2008 | Washing Machines
Lg washing machine pedistals
You will have to have the washer lifted to screw the leg back into the bottom. As far as the shaking...try some vibration isolation pads. www.keshakeaway.com the best $30 i have ever spent.I have a front loader on a pedestal also..it vibrated the pictures of the wall in the next room. with the pads I hardly know its running.( and the drawer stays shut)
Nov 10, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Whirlpool Duet GHW9150P Front Load Washer Logo
1,079 people viewed this question
Dan Webster
Dan Webster
Sal De
